Whats Causing Rain To Go Back Up Into The Soffits - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-26-2012, 03:51 PM   #1
Whats causing rain to go back up into the soffits
Bought my house about 6 months ago and noticed during some light rains that the rain did not flow off the roof properly, it would almost puddle back up under the roof a little... unfortunately I didnt think it was very serious... until TS Debby just came by...
It rained so hard that I noticed the first floor ceiling line getting wet, then I noticed the corner of my room with a big puddle of water...
somehow water has gotten into the block wall, and made its way down to the floor, then into the house... it also seeped outside and is bubbling the outside paint near the ground...
I dont know if the soffit issue is the cause, wanted to ask you guys what your opinions are...
thanx for your help/advice
Danny
Whats causing rain to go back up into the soffits-p6230076.jpg   Whats causing rain to go back up into the soffits-p6230078.jpg   Whats causing rain to go back up into the soffits-p6230079.jpg
dcastillo is offline   Reply With Quote
Old 06-26-2012, 04:29 PM   #2
Rewards Points: 252
Need overall pictures of the roof and close ups of anything above the area you are having a problem. If you have attic access pictures from there would help as well.
It looks like a lot of water is being directed to that area from an upper roof. It must be getting in the attic somehow and making it's way down the trusses.
shazapple is offline   Reply With Quote
The Following User Says Thank You to shazapple For This Useful Post:
dcastillo (06-26-2012)
Old 06-26-2012, 05:06 PM   #3
let me know if these help, just happened to have had them already
Whats causing rain to go back up into the soffits-p6230073-copy.jpg   Whats causing rain to go back up into the soffits-p6230074-copy.jpg
Old 06-26-2012, 05:08 PM   #4
John @ OHFS's Avatar
It may just be from the overwhelming volume and the surface tension of the water causing it to essentially be "sucked" up into the soffits. You may be able to remedy this by adding a supplemental drip edge to break the water tension...
John @ OHFS is offline   Reply With Quote
The Following User Says Thank You to John @ OHFS For This Useful Post:
Old 06-26-2012, 05:11 PM   #5
I am just wondering if something wasnt put together right though... I can uderstand that you may get a little leak due to the 10 inches of rain we got in one day!!!!, but it literally flooded the corner of my living floor with water... thats definitely not right...
Old 06-26-2012, 05:15 PM   #6
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
If the shingle were an inch to 1-1/4" past the drip ege, it wouldn't be wicking back in there. That's flush and capilary action is intensified.
Good old Florida Code in action.
tinner666 is offline   Reply With Quote
The Following 3 Users Say Thank You to tinner666 For This Useful Post:
dcastillo (06-26-2012), joecaption (06-27-2012), kwikfishron (06-26-2012)
Old 06-26-2012, 05:15 PM   #7
Determining whether or not it was put together right is hard to do from the photos provided. It may require a physical inspection, at least as far as I can tell anyway. I don't see any red flags other than the soaking wet soffit!!
Old 06-26-2012, 05:23 PM   #8
yep, same Red Flag I saw
Ive scheduled some inspections... but the soonest they can come out is 2 weeks away...
I just wanted to get some more opinions
It will also help out a lot when they are talking to me about the issue if I know a bit more myself, I havent had a ton of experience with roofing... until now
Old 06-26-2012, 06:55 PM   #9
kwikfishron's Avatar
Rewards Points: 86
Where's the step flashing?
It looks like 3 tab just gooped to 90 degree flashing stock to me.
kwikfishron is offline   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
dcastillo (06-26-2012), Windows on Wash (06-27-2012)
Old 06-26-2012, 07:18 PM   #10
good question, could it be under the stucco?
Im not sure if that would be the problem though, since there is an over hang above it, not much water flows along that edge...
thanx for pointing it out
Old 06-26-2012, 07:29 PM   #11
Rewards Points: 86
My first thought was the water was wicking back as tinner mentioned and that’s probably the case but I’d still take a peek in the attic to make sure all is dry.
Your roof to wall flashing looks wrong to me, or maybe I’m just seeing things.
Why don’t you have gutters? Properly installed gutters would eleminate the water wicking back.
The Following User Says Thank You to kwikfishron For This Useful Post:
Old 06-26-2012, 07:39 PM   #12
no gutters came with the house, I just bought it 6 months ago... it was built in 2000...
other side of the wall is a room, no attic, I would have to cut a hole in the wall to look around...
was thinking of removing the soffits to look around and see if I see anything, but then again I wouldnt really have an idea what to look for...
Old 06-27-2012, 08:13 AM   #13
Rewards Points: 1,294
Realy kind of hard to see in those pics but, does your drip edge have a small overhang like in this picture?...
I would also suspect capilary action drawing the water back under the overhang too. The little kickout on the dripedge looks almost flat in some sections. That could be bent out a little to "kick" the water away.
danpik is offline   Reply With Quote
The Following User Says Thank You to danpik For This Useful Post:
dcastillo (06-27-2012)
Old 06-27-2012, 09:33 AM   #14
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
Hard to say but I will go with what tinner and kwikfish said.
Step flashing (roof to wall intersection in general as the kick out looks a bit hard too) and capillary action.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 06-27-2012, 10:08 AM   #15
Bill Kearney
Rewards Points: 1,174
There has to be some sort of drip edge. If not then have one added. The idea is the surface tension of the water can allow it to wick back under the edge and down onto the fascia. How did the room flood? From the water getting in from above? Or from it puddling on the ground below? Sounds like you need rain gutters added either way. Control the water, get it away from the house.
wkearney99 is offline   Reply With Quote
The Following User Says Thank You to wkearney99 For This Useful Post:
Soffits and attic ventilation mikiek Roofing/Siding 3 06-03-2012 12:10 AM
Detached Garage Subpanel + Generator Back Feed insaneirish Electrical 3 09-06-2011 03:09 AM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 09:05 PM
Wooden Tongue & Groove Soffits Beverlyb Roofing/Siding 2 08-30-2008 11:31 AM
Moisture in walkout basement after rain storm dannox02 Building & Construction 2 01-24-2006 01:45 PM
