What's The Best Way To Get On A Roof. . . . - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-11-2011, 10:34 PM   #1
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What's the best way to get on a roof. . . .
Without damaging the rain gutters?
Is there a special ladder attachment for this?
Stupid question.
Journeyman Plumber
Old 04-11-2011, 10:54 PM   #2
Experienced
Jackofall1's Avatar
http://www.wernerladder.com/catalog/...?series_id=254
One of these will do the trick
Mark
Old 04-11-2011, 11:10 PM   #3
RFN-4A-LVN
Roofmaster417's Avatar
Stupid question.
I have 2 types and they are below.Ideally an extension ladder should IMO be placed on the rakeline of a roof.If your home is a hip roof or steep then a upper stabilizer is best to save your gutters.
The large stabilizer IMO isn't realistic for a homeowner unless you have ample room for storage.The top portion is wide and requires some space.The smaller is small storage friendly.Make sure you attach the stabilizer according to manufacture specs.
Also know ladder placement safety prior to using.The stabilizer should be attached so you have at least 2 1/2 to 3 feet above the gutters.Always have someone with you in case of an emergency.
No question is stupid when you are leaving the ground.IMHO
And depending on how many times its used will determine if constant assembly and disassembly is necessary.I never really trust bolts/nuts/washers when they are constantly tighten and disassembled.IMO
Roofmaster417 is offline   Reply With Quote
Old 09-23-2012, 05:14 PM   #4
Doing it myself
Alan's Avatar
Looking to buy one of these now, to put some moss-out on the roof.
The link above doesn't work, but looking at werner's site, they only show the stabilizer, not a standoff... (is it the same thing?)
I'm confused looking at the image because it doesn't seem like it would be enough distance to keep the proper angle on the ladder while still pushing the ladder away from the gutter with the stabilizer sitting on the roof.
Does anyone have experience with this particular product? I have a 28' werner extension ladder.
http://us.wernerco.com/view/Products...ssories/97/97P
Journeyman Plumber
Old 09-23-2012, 05:15 PM   #5
Doing it myself
Alan's Avatar
I may have answered my own question :
http://images.drillspot.com/pimages/7103/710317_300.jpg
Looks like the arms come off and flip around for roof access, and the other for leaning up against walls.
Still would like to hear a review on it if anyone has experience with it.
Journeyman Plumber
Old 09-23-2012, 05:19 PM   #6
Rewards Points: 12,802
Any of those shown will work, and the people that just ansewered your question do this type work every day and know what there talking about.
Lowes and Home Depot both stock ladder stand offs.
Old 09-23-2012, 05:33 PM   #7
chb70's Avatar
Pro Ladder Dok
I have been using these for about four years now.
RSC Builders, Inc
Can You Dig It!
Complete Roof
chb70 is offline   Reply With Quote
Old 09-23-2012, 05:43 PM   #8
Doing it myself
Alan's Avatar
The one I linked to only fits a 3" rail.... Mine are 3-5/16.
Any other suggestions?
Journeyman Plumber
Old 09-23-2012, 05:51 PM   #9
chb70's Avatar
Alan, did you check out this link that I posted Pro Ladder Dok you can buy them for a standard size 5" gutter or an oversized 6" gutter.
RSC Builders, Inc
Can You Dig It!
Complete Roof
Old 09-23-2012, 06:04 PM   #10
Doing it myself
Alan's Avatar
Yeah sorry, I should have mentioned that my gutters are plastic, so that isn't gonna happen.
Journeyman Plumber
Old 09-23-2012, 06:16 PM   #11
chb70's Avatar
No problem.
RSC Builders, Inc
Can You Dig It!
Complete Roof
Old 09-23-2012, 06:18 PM   #12
Doing it myself
Alan's Avatar
I wonder IF putting longer U-bolts on the thing would decrease the safety. I don't see how another 5/16 of an inch in length would hurt anything. Sent Werner an email to see about that.
Journeyman Plumber
Old 09-23-2012, 06:28 PM   #13
kwikfishron's Avatar
Rewards Points: 84
I have a couple of these, there the only ones I'll buy anymore. http://www.homedepot.com/webapp/wcs/...a#.UF-MebKPVN0
kwikfishron is offline   Reply With Quote
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 01:19 AM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 06:48 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 10:07 AM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
