What Type Of Roof Coating - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-01-2014, 01:30 PM   #1
Rewards Points: 31
What Type of Roof Coating
My 7 year old flat roof isn't necessarily leaking, but we've been having tons of side wall stucco leaks and I would like to coat the roof for added peace of mind. Some of the joints don't seem all that robust to me.
My question is.....what kind of coating would be best for my type of roof? It's light colored grit suspended in what I assume is a type of asphalt sheet. Seems a pretty standard roof material to me.
My plan was to pressure wash to remove dirt and any loose grit, then let it fully dry for a day and coat with something like an elastomeric coating from a supply store. I have easy access to my flat roof, so I was going to do this myself, seems pretty straightforward.
Any thoughts or product preferences for DIY'ers? Any ideas on how I can eliminate little valleys like the one in the pic? Thanks!
thetalkingmule is offline   Reply With Quote
Old 05-01-2014, 03:46 PM   #2
Low Slope Roofing
Rewards Points: 114
There is all kinds of coatings that are good, and as many or more that are worse. The issue is coatings don't fix leaks on low slope/ flat roofs. If you are getting leaks down walls it's likely there is a problem with the roof it's self.
No pics were attached. If you get some up maybe we could offer some better ideas.
1985gt is offline   Reply With Quote
Old 05-02-2014, 09:56 AM   #3
Rewards Points: 31
Did the pic not show up? This should work....
Old 05-02-2014, 11:31 AM   #4
Low Slope Roofing
Rewards Points: 114
Looks like the drip edge is just has a mastic over it. If it is that was done wrong. It needs to have a separate piece of felt then modified to strip it in. I'd bet that is why you are getting leaks down walls.
this can be done in cold process.
http://www.specjm.com/files/pdf/RS-4660.pdf
Old 05-02-2014, 02:35 PM   #5
Doing This Way Too Long
Rewards Points: 532
A roof coating is good to gain additional life out of your SOUND roof and it is a good idea to coat it every few years. . It is not going to repair existing problems with a bad roof.
You need to address the wall areas with a proper fix. It sounds like a termination/flashing issue which is not difficult to repair once you determine the exact problem but a coating is not the fix. THEN go ahead and coat the whole roof if you like as this will increase the useful life of the roof. You can use an elastomeric if you like but aluminum coat is going to give you the same benefit at a lower cost. Both products are only going to be a uv blocker basically and little else. The sun is the biggest enemy of your roof.
Inspect it every two or three years and re-coat when necessary.
Show us the stucco wall if you can
Roofing 101 - Think Like Water
OldNBroken is offline   Reply With Quote
Old 05-02-2014, 02:37 PM   #6
Rewards Points: 532
Hmmm, just noticed no cant strip on the wall in that pic. Not a good sign
Old 05-02-2014, 03:34 PM   #7
Low Slope Roofing
Rewards Points: 114
Good catch.
@op while the lack of cant strip may not be a problem now it will cause the sheets to break at the angle change in the future. The top of the wall should have really had a cap metal also instead of a gravel stop .Very hard to strip in a gravel stop on a 2x6 wall with a proper striping material.
Again I bet the leaks are caused by the drip edges/gavel stop not being striped in properly.
Everything OldNbroken said about coatings is spot on.
Old 05-02-2014, 07:49 PM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
Gravel stop...gravel schmop.
Nothing twelve tubes of caulking can't fix.
The Following User Says Thank You to Windows on Wash For This Useful Post:
1985gt (05-02-2014)
Old 05-04-2014, 08:18 PM   #9
Rewards Points: 31
Thanks a ton for the feedback everyone. Roofer is coming in a week to swap out two incorrectly installed skylights, I'll direct his attention to the items above and see what he thinks. I'll get that sort and THEN do some form of coating. Will update next week with anything of interest. Thanks again!
The Following User Says Thank You to thetalkingmule For This Useful Post:
1985gt (05-05-2014)
Old 12-25-2015, 12:04 AM   #10
Rewards Points: 14
I recommend you an aluminum roof panels. It's cheap, easy to install. Aluminium roof has many advantages, many people appreciate the convenience.
Importantly do not forget to make a sound insulation.
John567 is offline   Reply With Quote
Need opinion on this roof profenx Roofing/Siding 14 10-12-2010 01:56 AM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 11:02 PM
roof coating mj6971 Roofing/Siding 4 02-19-2009 10:18 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Reflective Coating on Flat Roof MelindaA Roofing/Siding 3 01-05-2006 06:08 AM
