Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-21-2009, 01:17 PM   #1
What type of roof?
Ok, so we are nearing the end of the design phase on our rowhouse addition and my architect and I have different opinions on what to do with the roof. You'll see from these plans, that it is a 2:12 slope shed roof attached to the existing home on two sides.
The architect has called for us to use a layer of water and ice shield (applied to the entire roof), followed by asphalt shingles. Under the method, we'd install soffit vents for intake and mushroof vent of some sort for exhaust.
I've been spending a lot of time on some of these forums and am pretty confident a flat roof membrane, like EPDM would work best given the very low slope. I've also heard that it is possible to "seal" the underside of the roof using spay foam, eliminating the need for ventilation.
So, what do you think? Which approach is best? Is there a method we're not thinking of? Which would be most economical? Most efficient?
Thanks!
stubits is offline   Reply With Quote
Old 09-21-2009, 11:19 PM   #2
Commercial Roofing
AaronB's Avatar
What type of roof?
Spray Poylurethane Foam roofing would be the best long term solution
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 09-22-2009, 12:00 AM   #3
What type of roof?
Hi, I have some question's , what direction is this roof or the back of your house facing? what is the climate like, where you live? Snow , rain, Wind?
What are the shingles on the rest of the House, and how old are they?
TD
telldon is offline   Reply With Quote
Strange Winter Roof Leak Dragon Roofing 16 10-09-2009 07:06 PM
what type of flat roof in coast home? starrider Roofing 7 02-19-2009 10:48 PM
Addition and Roof Replacement lebeld Roofing 4 01-04-2009 07:11 PM
Flat roof headache The Barber Roofing 7 05-17-2008 06:48 PM
Need Help on the Flat Roof and more... MelindaA Roofing 12 12-21-2005 11:12 PM
