What Type Of Metal To Flash Chimney And Masonry Wall? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-02-2008, 07:11 AM   #1
What type of metal to flash chimney and masonry wall?
I read somewhere that aluminum flashing is not good around masonry and chimneys because the alkali in the masonry corrodes the aluminum. Has anyone experienced this to be true ? If so, would painted aluminum alleviate this problem or is there another lower cost metal that works well for this purpose? (copper, etc. is not in the budget) Thanks in advance for your advice
Max1119 is offline   Reply With Quote
Old 05-02-2008, 08:31 AM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Lead is often used. Not sure this is a modern practice as I have only worked with old lead flashing set into the masonry when the chimney was built. I think this is called counter flashing and is used with step flashing when roofing.
Brik is offline   Reply With Quote
Old 05-02-2008, 09:27 AM   #3
That is supposedly true. I have read it in roofing and sheet metal and masonry manuals, but have never run into it in person. Maybe someone else has, but I have been roofing since 1978, so I would suppose that I would have run into it by this time.
Two of the villages around me even have that caveat listed in their building code guidelines.
If I do use Aluminum for my Counter-Flashings, I also use a seperator between the brick and sheet metal, such as Grace Ice and Water Shield. It is based on the customers budget and end resultant expectations. When I do use Aluminum, I use the .032 versus the thinner trim coil stock though.
The biggest problem, besides improper installation methods on chimney flashings that I see, is the usage of the tinner guage metals, which oil can and look all distorted, plus they do not have the rigidity of heavier stock to properly bend and insert where required to do so.
To this date, I have never seen any situation, Ever, where the masonry components have eaten through or degraded the Aluminum Flashings in any manner.
I have seen Galvanized flashings "Rust" completely through though.
I have also seen others use Aluminum Step Flashing Baby Tins with Copper Counter Flashings and the aluminum step flashings were eaten through as if eaten away by an acidic solution, which occurs due to the Galvanic Reaction.
But, just to be on the safe side, I always adhere the Grace Ice and Water shield around the entire brick masonry structure first, prior to mounting the sheet metal to the structure.
Ed
Ed the Roofer is offline   Reply With Quote
Old 05-02-2008, 11:04 AM   #4
Handyguy
Brik's Avatar
Thanks ed for clarifying - I have only done a handful of roofs. I did a tear-off/re-roof for a pastor in FL after Katrina came through. It was a straight forward job, one valley, ranch house, not a super steep pitch. Had a brick chimney for furnace I would surmise. Was on gable end so no cricket. It had lead counter flashing set into the mortar joints. We were able to peel it back, roof and step flash and push it back into place. The lead was in good condition so no need to replace it.
We used the grace in the valley and bottom edge as well as around the chimney as you suggested. In a warm climate I'm not sure as why the grace shield was specified but was on site and we installed it. I think the insurance company may have specified its use but I'm not certain about that.
Old 05-02-2008, 09:58 PM   #5
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro roofer, but I had aluminum step-flashing with aluminum counter-flashing installed over it around a triple-flue chimney (two woodburning fireplaces) on our A-frame when it was built in 1977. The exposed counter-flashing was primed and painted, and we have never had any problem whatsoever.
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-02-2008, 10:28 PM   #6
the roofing god's Avatar
Send a message via MSN to the roofing god
flash the perimeter with ice shield 1st,like this;
then you`ll have no problems
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 05-03-2008, 05:58 AM   #7
Thanks for the responses. Alot of really helpful info. I will use the ice/water shield and go ahead with the flashing. Thanks again
