-   -   What temp can i use this gutter seam sealer...? (http://www.diychatroom.com/f9/what-temp-can-i-use-gutter-seam-sealer-175970/)
sh40674 03-31-2013 02:28 PM
1 Attachment(s)
Attachment 68347
Wondering what temp I can use this stuff? Need to add a downspout... I'm sure I can use it in cooler weather but its in the 20s st night... Doesn't say anything on storage temps, usage temps, painting,etc... If there is a better product for caulking gutter seams please input.. Thanks guys!
PatChap 03-31-2013 07:38 PM
Do you plan on moving a downpipe or just adding another? If your moving one, the holes require a bit of work not to leak. Caulking sticks best to new metal, so heavy cleaning and a light sanding increase the odds of it working.
For just adding an outlet, as long as its positive temperatures you wont have any issues. If its half decent, it should set in most temperatures, just may take longer. I like Tremco sealants, but everyone has a preference.
jagans 03-31-2013 08:51 PM
Not sure on that one, but 100% Silicone has the widest temperature range from 40 below to 400 degrees above. Wipe the metal with Naphtha on a clean white cotton rag prior to application to remove mill oil. GE makes a good one that sets in like 30 minutes.
Clean up with alcohol.
mj12 04-02-2013 03:44 PM
take a utility knife, make an x in the bottom of the gutter, push the tabs down and screw your downspout in place. Downspout seams do not require sealer. Make sure overlap direction is right.
