What Size Plywood Should Be Used For A Carport Roof With Shingles? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-19-2008, 11:32 AM   #1
Rewards Points: 150
What size plywood should be used for a carport roof with shingles?
The roof over the carport is in not good shape. It has shingles. What is the correct size to use and that will last. Thanks.
twilightcall is offline   Reply With Quote
Old 01-19-2008, 11:39 AM   #2
Custom Cabinet Maker
1/2" minimum. depending where you live if it is down south and very humid I would use 1/2 pt
skymaster is offline   Reply With Quote
Old 01-19-2008, 11:40 AM   #3
Building and plumbing
USP45's Avatar
Rewards Points: 150
depends. If it were my house, 5/8. But I have used 3/4 toungue and groove also, though its a bit heavy. 7/16 is min I think. IMO, use 5/8.
USP45 is offline   Reply With Quote
Old 01-19-2008, 11:47 AM   #4
Rewards Points: 150
Thanks guys. I am down south. It is humid. Southern TN. The house was built in the 40s. Thanks Again.
Old 01-19-2008, 01:52 PM   #5
1/2" is probably the "Minimum" code where you are at, but 5/8" or 3/4" would not cost that much more and would be a better deck.
Ed
Ed the Roofer is offline   Reply With Quote
Old 01-19-2008, 01:56 PM   #6
Rewards Points: 150
what is your rafter spacing the plywood is nailed on?? Whats on there NOW and hows it feel and look? If you feel like your gonna fall thru walking on it,,better go heavier than current. 1/2 on 16's is marginal 1/2 on 24's are NO good. think 5/8 or 3/4 would be MUCH better. What slope?? ANY snow load??
justdon is offline   Reply With Quote
Old 01-19-2008, 02:17 PM   #7
the roofing god's Avatar
Send a message via MSN to the roofing god
justdon is right ,code is according to rafter spacing,1/2"for 16" on center,3/4" for 24" on center
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 01-20-2008, 03:11 PM   #8
so-elitecrete
Rewards Points: 150
always trust,,,
a roofing gawd & his angel, justdon
so-elitecrete is offline   Reply With Quote
Old 01-22-2008, 12:49 PM   #9
shingle over??? lemeno Roofing/Siding 12 12-01-2007 11:39 PM
dome roof - shingles / tin ?? hal12345 Roofing/Siding 1 09-22-2007 10:00 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
replace tar & gravel roof with shingles & torch down rt1035 Roofing/Siding 4 12-17-2005 05:39 PM
