Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-24-2012, 07:38 PM   #1
What size dumpster do I need?
I'm going to be removing 3 layers of shingles - 1 layer wood shake, 2 layers composite. What size dumpster do I need?
alyuka is offline   Reply With Quote
Old 09-24-2012, 07:55 PM   #2
Might want to let us in on how many squares it is for a better guess.
Old 09-24-2012, 10:16 PM   #3
Ha! Forgot the most important part. It's 16 squares.
Old 09-24-2012, 10:25 PM   #4
Exterior Construction
Windows on Wash's Avatar
20 yard should do it.
Shakes are pretty voluminous so if you are worried...go 30 yard.
Old 09-24-2012, 10:35 PM   #5
Might get by with a 30 yd. dumpster.
I like the kind with a door on the back so a wheel barrow can be rolled in and low enough sides that you can load from both sides.
Do not get one to small, not only will it not hold everything, but the truck that's going to need to lift it will be to small to pick it up. Not fun after loading it to have to then take them back out. (been there).
Sink Size Specs - Advice needed donvaz Kitchen & Bath Remodeling 1 08-12-2012 02:39 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 10:49 AM
Proper trunk/duct size? gjones HVAC 7 12-06-2011 08:18 PM
Dumpster Size For Tear down cbzdel Building & Construction 8 10-10-2011 11:26 AM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
