What Size Airline For Coil Nailer? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-29-2008, 10:07 AM   #1
What size airline for coil nailer?
I'm finally roofing this weekend and need to pick up some airlines and a coil nailer. I'm thinking about the Northern Tool coil nailer, good reviews and inexpensive. What size airline would anyone recommend? I see 3/8 and 1/4" but am not sure of the difference. Anyone know?
tidal9 is offline   Reply With Quote
Old 05-29-2008, 11:03 AM   #2
Registered User
Termite's Avatar
A 3/8" rubber hose is a good all-around hose. Spend the extra money on the rubber though...It is easier to manage.
Old 05-29-2008, 11:04 AM   #3
Its not worth going for a cheap nailer,they suck.Spend a few more bucks and get a brand name.Save some money and shop on Ebay $2-300 gets you a good gun,I use Milwaukees,but Bostich and Hitachi are the good ones.As far as airlines both sizes work,I personally like 3/8.Stay away from Pvc lines though,stick with rubber(IMO).Rubber is more flexible,Pvc tends to kink and doesnt wrap up good.Remember,you get what you pay for!!!Good luck.
johnk is offline   Reply With Quote
Old 05-29-2008, 06:59 PM   #4
Thanks for the suggestions!
Old 05-29-2008, 08:19 PM   #5
Check out the local Pawn Shops for a Roofing Nail Gun in good working order.
Hitachi and Bostich are the most common and most recommended.
3/8" rubber hose, but if you are only using it one time, then a 1/4" will suffice.
Ed
Ed the Roofer is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Compressor cfm rating required for framing nailer tmeehan Tools 8 05-01-2009 11:17 AM
Wire size and Breaker size for remodel ?? Skydmark1 Electrical 12 12-15-2007 05:00 PM
What size nailer to use for Soffit Replacement Mach5 Roofing/Siding 2 01-28-2006 11:24 AM
