What Sheet Metal Break To Buy? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-09-2012, 08:39 PM   #1
Rewards Points: 264
What sheet metal break to buy?
Is this a good sheet metal break?
http://www.amazon.com/Malco-MB48A-48...016393&sr=1-10
Or what would you guys recommend?
tibberous is offline   Reply With Quote
Old 04-09-2012, 08:58 PM   #2
Rewards Points: 13,270
What exactly do you plan on doing with it?
Old 04-09-2012, 09:14 PM   #3
Rewards Points: 264
Bend roll flashing into 4' sections to flash where the shingles meet the house.
Old 04-09-2012, 09:19 PM   #4
If this is just a one time job then why not just rent a break from Home Depot?
Old 04-09-2012, 09:25 PM   #5
Rewards Points: 264
Here
Old 04-09-2012, 09:28 PM   #6
Rewards Points: 264
Home Depot in my area doesn't rent tools. I would *think* that they would sell pre-bent runs of flashing, but for some reason, neither they, nor Lowes, carry any longer than the little pieces used for step flashing.
Old 04-09-2012, 09:35 PM   #7
Lowes and Most lumber yards carry prebent aluminum fashia, or any siding company could bend you what little you will need,
A roll of coil stock is selling from $75.00 to $85.00 a roll so by buying the brake, and the material it would be cheaper to just have a siding company do the whole job then to go buy the stuff you would never need again.
How do you plan on trimming out the arch? Think about using vinyl lumber.
Old 04-09-2012, 09:46 PM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Tapco: http://www.tapcotools.com/
Alumapole: http://alumapole.com/
- Build Well -
Old 04-09-2012, 09:52 PM   #9
Rewards Points: 264
Lol - that's just a picture I found on the internet as an example.
And I'm almost positive our Lowes doesn't carry pre-bent flashing. Should it be in the same area as drip-edge?
Old 04-09-2012, 09:55 PM   #10
Look in your yellow pages under siding and look for a real siding supply house.
Sheet metal under a rubber roof? what is going on here? philasheetmetal Roofing/Siding 2 07-12-2011 09:12 AM
Exposed sheet metal questions ohman Roofing/Siding 6 12-31-2010 11:46 AM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 06:54 AM
Getting shocked by multiple metal items in room thms Electrical 14 06-24-2010 02:23 PM
Best way to seal sheet metal to wood zootjeff HVAC 1 09-10-2009 08:06 AM
