Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-12-2008, 07:39 PM   #1
What roofing caulk is the best to seal flashing by chimney?
I have a small leak at the chimney in the flashing. I wanted to get a good roofing caulk so I could fix this. I have looked at Black Jack and many other brands. Any info would be appreciated. Thanks.
twilightcall is offline   Reply With Quote
Old 05-13-2008, 09:07 PM   #2
Geocel should make one, and PL makes a roof and flashing sealer.
My favorite product though is Pro-Seal 34. UV proof, instant seal, adheres to practically anything. Widely used on metals and metal roofing.
I don't want to dwell on the product though because it would start to sound like a advertisement.
You can check it out at prosealproducts.com
Docfletcher is offline   Reply With Quote
Roof Leak Around Chimney robertr4836 Roofing 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing 6 03-07-2008 04:12 PM
Suggestions on how to fill and seal an old chimney? drh Building & Construction 6 02-20-2008 10:27 PM
Flashing around furnace chimney from peak to eave? theredheadedstranger Roofing 2 10-25-2007 10:34 AM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
