What Is The Proper Size Of Gap In Sheathing For Ridge Cap? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-14-2013, 07:41 PM   #1
Rewards Points: 113
Question
What is the proper size of gap in sheathing for ridge cap?
Hi folks
I'm working on a 10'x10' shed with a 4/12 gable roof. What is the ideal sized gap in the plywood at the ridge for the ridge cap vent? My target was 3" on each side, but I forgot to figure for the fascia board so I ended with a little more than 4" on each side to the ridge. Is this acceptable or do I need to nail in a small strip of plywood or take some other action?
Thanks in advance
mklein49 is offline   Reply With Quote
Old 09-14-2013, 10:03 PM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
the gap should only be about 1 1/2" on each side. and kept back from the edge one truss spacing. where its a shed its not really needed if you have soffit venting and a gable end vent
woodworkbykirk is offline   Reply With Quote
Old 09-15-2013, 12:54 PM   #3
Rewards Points: 113
Ok so I messed up there. I do plan to have soffit venting and gable vents. Would you recommend just cutting a 4" strip for each side and completing the roof, or should I do something else?
Old 09-15-2013, 06:53 PM   #4
MarginallyQualified
Rewards Points: 2,464
With a ridge vent outlet.. soffit only for inlet works better.
Would you recommend just cutting a 4" strip...
I'd recommend following the instructions with the ridge vent.
Old 09-15-2013, 09:08 PM   #5
Rewards Points: 13,458
Way to wide a gap, now water can get in.
No need to gable vents of there's a ridge vent, in fact a gable vent will short circuit the ridge vent and make it useless.
Old 09-16-2013, 03:29 PM   #6
either way you only need 1 1/2" of space at the ridge per side. it sounds like you want 4" on both sides
Tags
gable , ridge vent and peak caps , roof
Who makes a smaller double door fridge? drew2000 Appliances 3 03-16-2013 07:41 PM
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-25-2011 11:29 PM
Proper awg wire size to use? Suzuki91vx800 Electrical 36 06-23-2009 04:18 PM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 12:12 PM
Tankless water heater proper pipe size? gante Plumbing 5 04-06-2009 02:28 PM
