What Is This Part Of The Gutter Called? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-31-2007, 10:10 AM   #1
What is this part of the gutter called?
See the attached picture. What is the tippy top part of the downspout in this picture called? It is the greyish box that funnels the water from the roof into the downspout? I need a new one but I dont know what it is called or how to find one.
Thanks,
Dan
DanBress is offline   Reply With Quote
Old 10-31-2007, 12:10 PM   #2
A Conductor Head or a Scupper Box, with ornamental detailing.
A sheet metal shop should be able to make one for you, especially if you bring in the old one for a sample template of profile and dimensions.
Ed
Ed the Roofer is offline   Reply With Quote
Old 11-02-2007, 04:48 AM   #3
the roofing god's Avatar
Send a message via MSN to the roofing god
leader head
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 11-04-2007, 08:09 PM   #4
How are the conductor heads typically attached to the wall? Mine is barely attached and it looks like it was done so by a rubber adhesive. What is the standard way to attach the box to the house? In my case my house is brick.
Old 11-04-2007, 08:41 PM   #5
drill holes w/masonry bit insert moly sleeves,and then screw into molys and seal molys w/ gutterseal
Carrier air handler blower part pwrengineer HVAC 8 04-16-2011 01:42 PM
Inducer Part Needed: Please Help! BDPNA HVAC 55 12-08-2010 09:48 AM
My house is a project...Part II "Deck Evolution" tigerbalm2424 Project Showcase 21 07-24-2008 11:37 AM
Need part for Craftsman Jointer sherlock Tools 5 11-11-2007 11:24 PM
facia repair and gutter boman47k Carpentry 2 09-11-2006 08:06 AM
