What Materials For Replacement Roof?? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-22-2010, 10:17 AM   #1
What materials for replacement roof??
Morning all! Our house is about 20 years old and we really need a new roof. What we have at the moment is asphalt shingles. Well, they are mostly there. haha
We have a house that has 3 very steep roofs that are all hipped. We have a set of blueprints for the house, and found the page showing the roof. There is a triangle by the roof that has 12 on the horizontal line and 9 on the vertical line.
We live in the high desert of Northern Arizona and have a lot of heavy wind and sand but not very much precipitation. 40 mph winds with gusts of 60 mph plus are not uncommon here. We get snow, but rarely have it stay on the roof (except for an inside corner facing northwest) for more than a day.
We are going to have someone else roof this, because of the steepness. We are just wondering -- which should we put on, metal or asphalt shingles? We are in our 50s at this point and haven't decided whether we will retire in this house, but probably will because it would just be easier.
We think we have put all the info you need to help us, but let us know any other questions. Thanks!
Kkasey is offline   Reply With Quote
Old 07-22-2010, 04:45 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Metal should last much longer. 50 year shingles should last 30 years or so.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Kkasey (07-23-2010)
Old 07-23-2010, 09:45 AM   #3
Thanks much for your reply!
We read someplace that asphalt shingles were better for steeper roofs. Is there any sort of reason metal wouldn't be good, or is it just a pain to install on a steep roof? Should we worry about the blowing sand eating the finish off?
We bought this house 14 years ago and have been replacing shingles every year since. Because of that, we are leary of replacing with the same.
We are hoping to get some advice from people who have opinions one way or the other. We would greatly appreciate some knowledge before we talk to a salesman. Of course when you talk to them, their product is always the best for the job. And when you try to research on the internet, you are usually reading what the manufacturer is putting out.
Old 07-23-2010, 10:37 AM   #4
Kasey - If I were in your shoes, I would look into a "higher end" shingle.
If your roof is how you described, and you get strong winds and have problems with shingles blowing off the in the past, I would personally recommend a 50 year shingle due to its added weight and higher wind resistance. Truthfully, the brand of the shingle (as long as its one of the bigger guys, gaf-certainteed, etc) would concern me less than the actual install. Due to it being a high wind area, I would ask any contractor how many nails they plan to put into each shingle. With the pitch, and wind problems, I would eliminate anyone who disagrees with using 6 nails per shingle.
As Tinner said, you can reasonably expect a 50 year shingle to last 30 years. No one knows for certain yet since they have not been in the market that long, but it should be the last roof you have to put on.
Paragon221 is offline   Reply With Quote
The Following User Says Thank You to Paragon221 For This Useful Post:
Kkasey (07-23-2010)
Old 07-23-2010, 12:05 PM   #5
We appreciate the info from both of you. 30 years would put us in our 80s and someone else should be worrying about that kind of stuff by then. Have a good one....
Flat Roof Materials & Application Question question Roofing/Siding 1 07-27-2010 02:08 PM
Need Advice ASAP. New home, seller is paying to replace roof elpa Roofing/Siding 4 02-18-2010 07:03 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 05:37 PM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
