What Kind Of Vent Is This? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-24-2013, 04:16 PM   #1
What kind of vent is this?
What kind of vent is this and where can I find a replacement? It is in bad condition and needs to be replaced. Thanks!
jdc7625 is offline   Reply With Quote
Old 04-24-2013, 05:29 PM   #2
Gymschu's Avatar
Rewards Points: 846
If you mean the vent on top of the chimney, it could be venting any number of things such as your furnace or hot water tank. Interesting that it appears to have FOUR outlets. I'm sure a roofer will be along to give you the proper name. I'm sure you could find an ample replacement at your local heating and AC distributor or even at your local Big Box hardware store. Just take a pic with you to show them what you need.
Old 04-24-2013, 05:51 PM   #3
The chimney portion is the part that needs replaced. It has deteriorated roofing cement on all sides.
Old 04-24-2013, 06:42 PM   #4
Doing This Way Too Long
Rewards Points: 532
Just looks like a 4" gas vent cap. Get one most anywhere, even big box stores.
Best to remove it and take it with you. It should only be attached by two small stitch screws.
And, yes, looks like your chimney could use some attn too.
If all the chimney is doing is venting your furnace you can also remove it below the roofline and flash the vent into the roof. Would be cheaper.
OldNBroken is offline   Reply With Quote
Old 04-24-2013, 07:47 PM   #5
Roofmaster
Rewards Points: 2,210
Looks like a fake chimney that someone ran a HWH or furnace flue through. I would remove the chimney, install a tall cone flashing and rain collar, and shingle it in. The flanges should be enveloped with Ice Dams Protection Membrane. I'm not sure if this is on the front or back slope of your home. I would re-route it to the rear slope. Definitely get rid of that hideous looking fake chimney, or whatever it is.
Old 04-25-2013, 06:28 PM   #6
It looks like its venting the HWH. If I remove the chimney can I just run a straight pipe?
Old 04-28-2013, 12:11 PM   #7
IT looks to be a masterflow vent cap.
http://www.homedepot.com/p/Master-Fl...0#.UX1X_8ptCSo
k20vteck20 is offline   Reply With Quote
The Following User Says Thank You to k20vteck20 For This Useful Post:
Gymschu (04-28-2013)
Dryer vent installation Wiscbldr Building & Construction 3 05-04-2011 03:14 PM
Vent sizing pment Plumbing 5 04-19-2011 07:21 AM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 09:35 PM
Attic Ventilation Question handy man88 Roofing/Siding 10 02-12-2010 10:50 PM
finishing a basement bath - tie in to ejector pump vent? ajbowman Plumbing 7 04-15-2008 12:09 AM
