What Goes First Roofing Or Siding - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-22-2010, 10:10 AM   #1
what goes first roofing or siding
In a remodeling job can the siding go first before the new roof to be installed?
ME4756@AOL.COM is offline   Reply With Quote
Old 09-22-2010, 11:40 AM   #2
Rewards Points: 52
Pretty much your call. The primary thing, before installing either, is to make sure that your wall and roof framing is adequately squared and braced before proceeding. After that, the rest of the concerns are pretty obvious, i.e. water intrusion, ladders against new siding, etc., so if you've accounted for all of that, go forth young man.
DexterII is online now   Reply With Quote
Old 09-22-2010, 12:09 PM   #3
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
The siding can go first if your roofers know what they are doing, but you will get a much much better job if the siding comes after the roof. Having said that the siding guys must know how to work around the roof without damaging it.
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 09-22-2010, 01:41 PM   #4
kwikfishron's Avatar
Rewards Points: 176
Always the roof first if there are any roof to wall connections. Kind of hard to step flash after the sidings up.
Siding guys would never damage a new roof.
kwikfishron is online now   Reply With Quote
Old 09-22-2010, 02:13 PM   #5
Rewards Points: 117
If you're really lucky (as I was), first the roofers will staple their step flashing to the wall as they're roofing, and then the siding guys will cover up the staples, making it a complete PITA to remove the step flashing when you have to re-roof.
spiragui is offline   Reply With Quote
Old 09-22-2010, 04:03 PM   #6
Grumpy's Avatar
That's why we do not fasten our step flashing/ baby tins tot he wall. However I wold say 98% of the roofs we replace have existing siding and we have learned to work with this. It's not always necessary to remove the siding to replace the step flashings, and when it is we charge for it and temporarily remove the siding to expose the wall and step flashings. That's why i say the roof should come first, because if the siding is being done the roofs can rip up the siding and not have to fix it. But if the siding is done first we have redundant work removing and reinstalling new siding, not to mentionin voiding the warranty of someone elses work.
-Grumpy
Old 09-22-2010, 06:03 PM   #7
MJW
It's best to have a Contractor who has a crew that does both and have them do the job.
MJW is offline   Reply With Quote
Rot under vinyl siding zackinma Building & Construction 1 12-28-2009 11:07 PM
Roll Roofing Edge Leak toolboxone Roofing/Siding 5 10-07-2009 07:09 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
