What Do You Think Of My Roofing Job? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-02-2008, 07:39 AM   #16
747
registered
747's Avatar
Rewards Points: 534
in pic two why is there a fastback louver vent under the ridgevent? Also those shingles look like the ones i had put on my sisters house over the summer. Certainteed landmark 30ar mission brown. I could be wrong but if not they are real similiar in color. Also the fast back brown louver vents are exactly like the ones the roofer put on the back of my sisters ridge. He ran 11 of those like every 3 or 4 feet or so.
I sure hope it flattens out for you.
747 is offline   Reply With Quote
Old 12-02-2008, 12:35 PM   #17
Doing This Way Too Long
Rewards Points: 532
As the person on that website states "It doesn't show you how to do this valley on the wrapper". It doesn't show you how to do it in any mfr literature whatsoever because it is not a mfr recommended detail. As I said, it's lazy roofing
OldNBroken is offline   Reply With Quote
Old 12-07-2008, 02:37 PM   #18
Commercial Roofing
AaronB's Avatar
Originally Posted by butlersprints View Post
I would be concerned about the old flashing. sounds like they didn't want to take time to remove siding to flash with new, however new roofing should have new flashing as well. never know if old flashing was done correctly.
This costs money and should have been addressed at the time of the sale. If it wasn't then there has been a lack of communication.
I agree that you can never tell if the old flashing was done correctly.
One major problem with installing all new flashings is the fact that you have to remove and replace siding, which brings up a whole new scope of work, that many homeowners dont want to deal with or pay for, etc.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 12-07-2008, 02:39 PM   #19
Commercial Roofing
AaronB's Avatar
Originally Posted by uncleslam View Post
Another thing that is bugging me is that the new shingles extend past the drip edge by 1 inch. The old shingles stopped about 1/2 inch before the edge of the drip edge. Which is correct?
Also, in my contract it says "woven valleys" but I don't think that what I'm getting. Guess I got bent over.
One inch past drip edge is good.
You did not get woven valleys. You got the half-jacked valley. they just lay a shingle up the valley and butt the shign les to the inside edge. BS way of doing it. It takes skill to lay a proper valley.
Old 12-07-2008, 02:45 PM   #20
Commercial Roofing
AaronB's Avatar
It doesn't feel good. I have some concerns about the venting. They used one of the cheapest vent systems available, cobra brilopad (exhaust vent). Then they installed 2 of the 3 intake turtle vents up high on the roof instead of down low - I don't see what they were thinking there.
Yes that venting is jacked up.... those can vents are short-circuting your air flow. Only the air at the top is getting turned over because air takes the path of least resistance and is being sucked in through the cans and out through the ridge.
The rest of the attic air is still there... all stagnant and hot and moist and icky.
Old 12-07-2008, 02:46 PM   #21
Commercial Roofing
AaronB's Avatar
I would have vented the soffit ,if it wasn't. jmo after further reveiw, there doesn't appear to be soffits.
Smart Vent handles this situation well.
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 06:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 06:32 PM
Dishonest roofing companies, or corporate propoganda? KAdams4458 Roofing/Siding 23 11-26-2008 09:33 PM
Metal roof??? Tdoggy187 Roofing/Siding 51 03-04-2008 04:35 PM
Roofing felt mattflytx Roofing/Siding 2 09-10-2007 12:01 AM
