What Do You Call This - Roofing/Siding - DIY Home Improvement | DIYChatroom
Like Tree2Likes
  • 1 Post By mikegp
  • 1 Post By mako1
Old 06-02-2016, 09:30 AM   #1
Rewards Points: 103
What do you call this
Guys, what do you call this metal sheeting? Where would I go to get this replaced if I rip it out. If I wanted to hire someone to do it, would it be a roofer, siding guy, etc. When it rains here I can hear some water dripping onto the metal from the roof peak. I want to take this down to investigate the leak. I also want to run a light to hang in the middle. I'm just worried that if I damage this ripping it out that it will be difficult to get replacements for.
Also any advice on taking this down? There is one strip of nails right through the center the outsides are not nailed but it dosent seem to want to flex at all or allow me to slip any of the pieces out. Mis there a trick to it? Thanks in advance everyone.
Mike
Mlorek is offline   Reply With Quote
Old 06-02-2016, 09:31 AM   #2
Rewards Points: 103
Re: What do you call this
One more view
Old 06-02-2016, 09:49 AM   #3
Rewards Points: 1,476
I call them soffit panels.
de-nagorg likes this.
mikegp is offline   Reply With Quote
The Following User Says Thank You to mikegp For This Useful Post:
Mlorek (06-02-2016)
Old 06-02-2016, 11:34 AM   #4
Rewards Points: 2,360
Those are standard soffit panels.
Easily replaced if you bend them removing them.
They are installed in a J channel framework, Replaceable too.
Any decent siding contractor can replace them if you decide too.
And good handyperson can do just as well and cost for just the material.
When putting in a light , you need to frame the light and wire before installing the soffit, then just trim it out with the soffit.
ED
de-nagorg is online now   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
Mlorek (06-02-2016)
Old 06-02-2016, 07:10 PM   #5
Rewards Points: 103
Thanks guys for the help
The Following User Says Thank You to Mlorek For This Useful Post:
de-nagorg (06-02-2016)
Old 06-10-2016, 01:22 PM   #6
Household Handyman
Rewards Points: 1,408
I now the OP stated "metal panels" but I just have to ask: Are these indeed metal, most likely aluminum, or vinyl soffit panels?
Old 06-10-2016, 02:12 PM   #7
Rewards Points: 144
As everyone said those are soffit panels.Most likely aluminum.Thurman : Last I heard aluminum was "metal." They do also come in vinyl.
mako1 is offline   Reply With Quote
Unwanted phone call ron45 General DIY Discussions 12 02-15-2015 06:31 AM
so, i call JULIE Fix'n it General DIY Discussions 16 05-02-2014 02:28 PM
When do I call the plumber? ctote Plumbing 4 07-07-2011 11:28 AM
Contractors Venting Thread. Long. Doc Holliday Off Topic 7 05-23-2011 09:18 AM
