What To Do With Shingle Nail Ends When Sistering Rafters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-20-2012, 06:55 AM   #16
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
just hold the doubler down the thickness of some added plywood strips between the nails in the way, you will be fastening the sisters to code....yet will still have full bearing, and not effect the nails. Simply add the same ply to the existing rafter bottom for the rake wall plate to support fully.
That's just plain silly. Then every other rafter in plane would have to be furred if the ceiling is to be finished. Most answering here are not looking at the big picture. The answer has already been given. Clip the nails to get the sisters in. Those clipped nails will end up getting pulled when the dormer is framed. The dormer walls will be over the sistered rafters or near enough that the nails in question will have to be pulled to flash. Even if they weren't, only one nail per shingle would be affected. Carry on.
seeyou is offline   Reply With Quote
Old 03-20-2012, 10:40 AM   #17
as stated already, clipping is probably easiest. If you have plywood decking, that will help the nail remain tight after the clip. If its OSB though, all bets are off due to its inferior nail holding properties. another option is to locate where the nails will contact the new sistered rafter and drill a small hole so as to allow the nail some clearance. its only 2 sisters that you are doing so it shouldnt be too many to drill.
Hates my roof is offline   Reply With Quote
Old 03-20-2012, 10:42 PM   #18
Registered User
Rewards Points: 526
Cutting the sister to the exact same length/configuration with the ridge/seat cuts and installing it diagonally with only 22-1/2” or less- 14-1/2” is very difficult (with or without nails in the way…). I would cut it exact, then, level cut the seat cut by 1-1/2” shorter. When swinging the bottom of rafter over to double- with the top where it belongs, every little bit helps. Install the rafter; lift it up on a 2x4 spacer (1-1/2”) on the plate, after cutting only the few nails in the way. As you said your location is not FL but another sunny/tropical area? You may want/need the nails protruding if in a Gulf Coast high wind area. Where are you located?
Gary
Old 03-21-2012, 01:00 AM   #19
Ole Wood Worker
BigJim's Avatar
Rewards Points: 576
Gary
Dead on, looks like you have had to sister a rafter also.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
jcrack_corn (03-24-2012)
Old 03-21-2012, 02:27 AM   #20
kwikfishron's Avatar
Rewards Points: 824
Originally Posted by tinner666 View Post
Clip them off flush. The parts in the air aren't holding anything.
Exactly…I’d whip out the Hoof Clippers and be done with it.
In this case a Sawzall is to aggressive imo.
kwikfishron is online now   Reply With Quote
Old 03-21-2012, 07:19 AM   #21
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Some of you are missing the boat here. Quote--"I need to sister a couple of rafters in (full length sisters) to support new dormers. Sisters were spec'd by engineer."
The dormer framing will sit ON the sistered rafters.
Now, to the OP; Once you determine the exact outside position of the framing, figure out the thickness of your outer layers, insulation, siding, etc. Hold a line there too. Don't snap a line there! This should give you the range of area where all the nails now need to be removed, and 6" more to the outside of that line.
At the line marking the dormer framing, pop a line 1/2" from the framing line. This is where the shingles need to be cut off. Remove all shingles between these lines you marked on both sides of the dormer location. Now, you can put your framing directly to the roof deck, AND have some play to slide in your step flashing.
Call me if you need any further help/clarification.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Old 03-21-2012, 11:00 AM   #22
Registered User
Rewards Points: 526
Sigh..... read the last part of post #7...... now we are running in circles, "Great minds think alike" though! The other problem is getting the rafter in place without stopping because of protruding nails (virtually no wiggle-room- as a carpenter would know)---- without cutting them IF in a high wind area. Which I think "jcrck corn" is in from reading some of his earlier posts last year. Are you listening, jcc?
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 03-21-2012, 12:49 PM   #23
Pro Slate Roofer
tinner666's Avatar
True enough GBR!
Old 03-24-2012, 08:46 AM   #24
Rewards Points: 282
Thanks, this is what I did. I like to work alone and they are 26 ft FG 2x8's....approx 60 pounds with a CG 13 feet away from me at all times, lol. but just taking my time and using rigging pulley and its all going well.
I actually have about a 4" HAP, and deep, well built soffits so I am able to get away with cutting the seat about 1/2" shorter than exact...i can slide the 2x8 into the soffit, then climb the ladder and pull it up and twist into place.
I am getting the ridges perfect. and have that 1/2 gap at the seat. I will shim that up and hurricane tie it...but I will also be building a double 2x4 triangle box that will drop down from the bottom edge of the rafters about 1ft up from the seat, down to a steel beam (then back to the end of the rafters on the seat, to complete the triangle for added rigidity, prevent movement). So the top plate isnt going to carry much load anyway...it will be picked up by the kneewall and the steel beam (all engineered).
its to support new dormers. I ended up cutting the nail shank on about 20 nails...not worried at all (and yes, hurricane area)...most of where I cut will be stripped when the exterior dormer walls go up anway...and i'm 50/50 odds for a new roof on that side if the shingle match isnt good enough.
I have 5 more to go, so I might try your way (just saw your post) to make it even easier.
ohh, and with the steep pitch I will be able to install hurricane ties when finished.
at the top i already have collar ties (that happen to be on the sides opposite sides i'm sistering, yah! one thing i dont have to move!), and plan to also run the new ceiling joists full lenth rafter to rafter on the other side of the house (dead space) so they will function as ties about mid span, along with the new/old floor joists (2x6, with sistered 2x12) tieing them at the bottom. I think a hurricane will take the rest of the house before it takes this part! lol
Gary
jcrack_corn is offline   Reply With Quote
The Following 2 Users Say Thank You to jcrack_corn For This Useful Post:
Gary in WA (03-25-2012), seeyou (03-24-2012)
Old 03-24-2012, 08:50 AM   #25
Rewards Points: 282
yep, you got it! i may have a single nail here or there that i cut outside of where the new rafters are but no biggie. but yes, dormer walls will sit over where I'm cutting most of the nails.
BTW to all....sawzall with long metal cutting blade is by far the way to go...plenty of room to get flex to make a flush cut, no damage to decking. takes probably less than 10 seconds per cut, no effort at all.
The Following User Says Thank You to jcrack_corn For This Useful Post:
seeyou (03-24-2012)
Old 03-24-2012, 09:02 AM   #26
Rewards Points: 282
btw...for those interested....the engineer spec'd 2 w8x21 beams (24ft span).
One carries half the floor load, about 20x24 tributary. the other one will carry 1/4 the floor load and the dormers. (which aren't huge, about 4'8 wide between the new rafters, and 8 foot walls with 2'4" additional ceiling height with the vaulted dormer rafters (on same 12/12 pitch).
the w8x21's seem up to the task, i believe there is quite a safety factor there.
Garage ceiling insulation MNHouseRepair Insulation 16 12-05-2011 02:57 PM
AIR VENT SHINGLE VENT ll Docfletcher Roofing/Siding 8 06-04-2011 09:05 AM
Nail popping shingle Slyguysmoke General DIY Discussions 1 04-22-2011 05:55 PM
hip shingle torn and roof nail exposure timcsi Roofing/Siding 1 09-29-2010 10:09 AM
Can i Nail down Laminate Floor ends? (seperating) EuroZ24 Flooring 4 11-26-2009 07:50 PM
