What To Do With Shingle Nail Ends When Sistering Rafters - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-16-2012, 10:49 PM   #1
Rewards Points: 282
What to do with shingle nail ends when sistering rafters
I need to sister a couple of rafters in (full length sisters) to support new dormers. Sisters were spec'd by engineer.
anyway, there are many spots where i have shingle nails protruding where the sisters will be....all the nails protrude about 3/8"-1/2"
so what should I do in this case, I dont think bending them would be a great solution because the exposed shank is so short....I definitely dont want to back them out, then hammer back into the sisters once up...
so that leaves me with clipping them (shouldnt be a problem with a strong pair of nippers).
whats the standard thing to do in this situation?
thanks!
jcrack_corn is offline   Reply With Quote
Old 03-16-2012, 11:02 PM   #2
Rewards Points: 13,968
Sawsall with a metal cutting blade. Takes about 10 sec. per nail.
Old 03-16-2012, 11:07 PM   #3
Doing This Way Too Long
Rewards Points: 532
or a peanut grinder. Smoother than the snips.
OldNBroken is offline   Reply With Quote
Old 03-17-2012, 12:52 AM   #4
Rewards Points: 282
thx! never considered the sawzall...just picked up some new blades too.
Old 03-17-2012, 04:42 PM   #5
RFN-4A-LVN
Roofmaster417's Avatar
Might be overkill but maybe you should seal the bottoms of the shingle where your cutting the nail points.Or pull the nails along the length of the truss then refasten.
Roofmaster417 is offline   Reply With Quote
Old 03-17-2012, 05:06 PM   #6
Rewards Points: 532
Yeah but you gotta remember it's only a few nails and they are still penetrating the sheeting. In the whole scheme of things it's not gonna affect the integrity of the roof.
The Following User Says Thank You to OldNBroken For This Useful Post:
seeyou (03-18-2012)
Old 03-17-2012, 11:20 PM   #7
Registered User
Rewards Points: 526
The fasteners are code required to enter 3/4" in wood or penetrate the sheathing. “R905.2.5 Fasteners. Fasteners for asphalt shingles shall be galvanized steel, stainless steel, aluminum or copper roofing nails, minimum 12 gage [0.105 inch (3 mm)] shank with a minimum 3/8-inch (10 mm) diameter head, ASTM F 1667, of a length to penetrate through the roofing materials and a minimum of 3/4 inch (19 mm) into the roof sheathing. Where the roof sheathing is less than 3/4 inch (19 mm) thick, the fasteners shall penetrate through the sheathing. Fasteners shall comply with ASTM F 1667.” From: http://publicecodes.citation.com/ico...005_par007.htm
I wouldn't cut them flush for a few reasons other than code; grinding them will heat the nail to melt the asphalt shingle there- reducing it's holding ability in high winds, cutting will loosen/expand the wood surrounding it for less withdraw power also, but mainly---- you need to step flash the dormer side walls that require framing directly on the sheathing after removing or at least inserting the step flashing before framing them. Requiring pulling shingles the width of framing plus side wall sheathing to the new metal flashing.... 4"- 6" (2x4 or 2x6) back from the doubler anyway, right?
Gary
Old 03-17-2012, 11:37 PM   #8
Rewards Points: 532
Once again, his roof is not going to blow off just because he sheared a few nails off to sister a rafter.
seeyou (03-18-2012)
Old 03-18-2012, 07:11 AM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 524
But he will have humps in his shingles where the nail works back out with nothing left to hold the nail in place. As Roofmaster417 said, pull the nails you need and renail after installing the other rafters. I would be interested to see how he gets a full length rafter in place, without altering it, there are going to be other roofing nails sticking through the bottom of the decking for him to slide the rafter not to mention dealing with the thickness of the 2X at the plumb cut or the birds mouth. It is not not going to be easy.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 03-18-2012, 09:58 PM   #10
RFN-4A-LVN
It may or may not ever be an issue.I just thought it was something to think about.IMHPO I would do it on a customers home (Pull & Refasten)but might not on my own home.
But I am sure if my wife heard about my comment about it being O.K for my house I would have to delete this,burn my hard drive then deny it till my dying day.
The Following User Says Thank You to Roofmaster417 For This Useful Post:
Tom Struble (03-18-2012)
Old 03-18-2012, 10:19 PM   #11
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Simple solution: Nail Dikes/cutters.
Looks like this: http://www.amazon.com/JT-Tough-1-Nai.../dp/B002HICAXS
I understand Gary's point, especially in high wind regions. So, it may be prudent to take reference measurements, and go roof-top to add some shingle nails and sealant (where needed).
- Build Well -
Old 03-19-2012, 03:57 PM   #12
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
Bwhahahahahaha
seeyou is offline   Reply With Quote
Old 03-19-2012, 04:37 PM   #13
Ole Wood Worker
BigJim's Avatar
Rewards Points: 524
We aren't going to call and tell your wife, we are just going to ask her does she know it.
Jim
Old 03-19-2012, 06:01 PM   #14
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Clip them off flush. The parts in the air aren't holding anything.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
OldNBroken (03-19-2012)
Old 03-20-2012, 01:07 AM   #15
Registered User
Rewards Points: 526
I would think the longer the fastener, the longer it stays in the sheathing in a high wind. Correct, overall, it isn't that big a deal, as I said earlier, the main reason.... Yet, the extra 1/8" is required by some shingle manufacturers for the full warranty: Tamko product, 2.4 B: http://onlineplanroom.docucopyllc.co...image_id=80019
CertainTeed products; http://www.certainteed.com/resources...arkinstall.pdf
And with a quick search: If live in Missouri, pp. 16, 2.5 B: http://oa.mo.gov/fmdc/dc/fmdc_dip/6%...n%20Manual.pdf
Peer pressure: 1/8" required: NRCA, ARMA, pp. 24, #387: http://www.armamembers.org/Meeting/p...20Comments.pdf
jcrack corn, Jim (jiju1943) made a good point, just hold the doubler down the thickness of some added plywood strips between the nails in the way, you will be fastening the sisters to code....yet will still have full bearing, and not effect the nails. Simply add the same ply to the existing rafter bottom for the rake wall plate to support fully.
Gary
Garage ceiling insulation MNHouseRepair Insulation 16 12-05-2011 02:57 PM
AIR VENT SHINGLE VENT ll Docfletcher Roofing/Siding 8 06-04-2011 09:05 AM
Nail popping shingle Slyguysmoke General DIY Discussions 1 04-22-2011 05:55 PM
hip shingle torn and roof nail exposure timcsi Roofing/Siding 1 09-29-2010 10:09 AM
Can i Nail down Laminate Floor ends? (seperating) EuroZ24 Flooring 4 11-26-2009 07:50 PM
