What Do I Need - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-02-2006, 10:26 AM   #1
What do I need
Hi
I live in a semi built in 1936. The roof was secured to prevent roof spread/spay with steel wires. Over the years the wires rusted and to combat roof spread wood was used as a replacement to these braces this has worked well, but has meant a loss of roof space. I want to get this space back by placing metal bracing lower down the roof frame connecting to the ceiling joists. I know I can buy these brackets/braces but don't know what they are called or if they are standard size???? I am not looking to do a roof conversion just get back the space for storage without having to dodge the existing bracing.
Thanks for the help.
I would post up a diagram I have if I knew how to do it.
bill123 is offline   Reply With Quote
Old 09-04-2006, 08:03 PM   #2
Rewards Points: 150
???, what the hell you talking about anyway?
RooferJim
RooferJim is offline   Reply With Quote
Old 09-04-2006, 08:28 PM   #3
Building inspector
inspects's Avatar
I think?....your talking about steel wire cables with turn buckels...yes?
If so, before I started just attaching anything to the roof framing and making structural modifications an architect should draw your intension's and submit them for approval in your local jurisdiction.
P.S. I don't think you'll get a permit to do what your trying to explain.
inspects is offline   Reply With Quote
Old 09-05-2006, 03:18 PM   #4
Thanks but it's sorted.
