What To Cut A Hole In OSB? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-29-2013, 09:29 PM   #1
What to cut a hole in OSB?
I have a tight space in the attic where I need to cut an opening into a false roof to blow some insulation (around knee height). 1/2" OSB. What would you guys suggest I use that is best suited for this? Reciprocating saw?
Thanks,
Sonic
SonicExplorer is offline   Reply With Quote
Old 05-29-2013, 09:45 PM   #2
Framing Contractor
Rewards Points: 112
Yep! If you have the room, a circular saw with an old blade will work also.
sixeightten is offline   Reply With Quote
Old 05-29-2013, 09:50 PM   #3
Roofmaster
Rewards Points: 2,172
Just drill upper left corner, and lower right corner with a paddle bit. Cut out a square with your sawsall. You can also use a multi tool, or a roto-zip.
Old 05-29-2013, 10:34 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,972
Don't care for the reciprocating saws in OSB as it will tend to tear the chips at the cut.
An oscillating/multi tool can work great as well as an angle grinder and roto zip.
The Following User Says Thank You to Windows on Wash For This Useful Post:
ddawg16 (05-30-2013)
Old 05-30-2013, 12:03 AM   #5
Doing This Way Too Long
Rewards Points: 532
Do ya own a hammer?
OldNBroken is offline   Reply With Quote
Old 05-30-2013, 12:11 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,154
Hole saw works well....best part....it holds on to the piece it cuts out....except for some saw dust...it's pretty clean.
ddawg16 is online now   Reply With Quote
Repair Small Hole in Vinyl Siding Silkcityflorida General DIY Discussions 12 04-08-2013 04:34 PM
Cutting Hole for Bathroom exhaust jburchill Kitchen & Bath Remodeling 14 04-16-2012 12:55 PM
patching hole in 8" concrete block BlueBSH Building & Construction 5 08-09-2011 07:55 PM
Need to enlarge hole in wood top plate: or use flex with minimum OD. mysterylectric Electrical 3 08-09-2011 03:52 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
