Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing/Siding
Old 01-13-2013, 05:51 PM   #16
What is the correct drip edge overlap for shingles
Pat, we are in sarnia lambton
Peter683 is offline   Reply With Quote
Old 01-13-2013, 06:44 PM   #17
RFN-4A-LVN
Roofmaster417's Avatar
Originally Posted by Peter683 View Post
They used the black tar paper along the first couple of feet..
Hopefully they covered the entire roof with felt.
Roofmaster417 is offline   Reply With Quote
Old 01-13-2013, 06:45 PM   #18
I don't think so..
Old 01-13-2013, 06:47 PM   #19
Got me worryed now.
If they only used tar paper up the lower part of the roof, what did they use on the rest of the roof.
I'm shocked it's not code to use Storm and Ice up that far north.
One of the more common issues with roofs is with ice dams,
Old 01-13-2013, 06:49 PM   #20
I can't say if they did or not Joe as we werent watching them all the time .. something tells me know.. We did use it on the whole roof on the garage.
Old 01-13-2013, 06:52 PM   #21
RFN-4A-LVN
Hmmm,if you have plank decking on the house you should be able to tell if felt was used with a flashlight.Just shine it between the boards.Felt looks different than the shingle back.
Old 01-13-2013, 06:53 PM   #22
Not required here to paper the whole roof. Should have been at least offered to you, however.
PatChap is offline   Reply With Quote
Old 01-13-2013, 06:56 PM   #23
Now that's just wrong.
I would not every think of doing a roof without felt
Old 01-13-2013, 07:14 PM   #24
Just a regional differance. I find more then just one course of paper on maybe 5-10roofs a year that I redo.
Old 01-13-2013, 08:33 PM   #25
Roofmaster
Thats right, One knuckle for both the starter course and the first course, past the Break in the metal drip edge, which is enveloped in Ice Dams, of course.
Thats an inch unless you are Abe Lincoln.
Whaaaaa No Felt????? You must be Yanking My Chain, Yes?
Joes Right, and make that ASTM D226 Type 1 Felt, at that. And it aint "PAPER"
" A lot of men build things, and a lot of things fall down "
Old 01-13-2013, 09:36 PM   #26
Ontario building code isn't online, but here's a link to a ruling relating to the eave protection code. Scroll down a bit to 4 *provisions of the Ontario building code*. Is related to the 1992 code, only change has been that cementing 2 layers of 15 together is no longer allowed, #30 min now.
As I said its just a regional difference.
http://www.mah.gov.on.ca/Asset7749.aspx?method=1
If you'd like to see the newer code, I can take a picture of the current code book tomorrow.
Old 01-13-2013, 10:44 PM   #27
747
registered
747's Avatar
It depends on the roofer. At least 1/4 inch. For a clean look. Let them overhang. Then once roof is completed. Snap a chaulk line and cut all at once. Some roofers do it like this others cut as they go.
747 is offline   Reply With Quote
Old 01-14-2013, 11:47 AM   #28
Roofmaster
No, it does not "depend on the roofer" Its one inch, +- 1/4 inch.
Geezzz.
Old 01-14-2013, 12:10 PM   #29
RFN-4A-LVN
I probably did a good 75 roofs last year with no felt.Most were steep but a few lower slopes in the mix and none were leaking.Nothing in the valley's and zero leaks.
Old 01-14-2013, 12:12 PM   #30
RFN-4A-LVN
Interesting.
Should installed drip edge cover fascia board? dilerin Roofing/Siding 12 11-04-2012 03:03 PM
Question about metal roof on shed and drip edge genEus Roofing/Siding 8 09-30-2012 10:27 AM
Vented Drip Edge problem vadifey Roofing/Siding 5 08-29-2012 04:20 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 03:10 PM
Drip edge mattflytx Roofing/Siding 3 09-09-2007 11:53 PM
