What Is 'cold Set Asphalt Adhesive'? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-13-2010, 05:26 PM   #1
Rewards Points: 682
What is 'cold set asphalt adhesive'?
I plan to do some roll roofing. I've read I should use 'cold-set asphalt adhesive'. I was planning to use the regular roof cement down at the hardware store. Should I get a special 'cold setting' type of roof cement?
darsunt is offline   Reply With Quote
Old 10-13-2010, 05:59 PM   #2
DIY Roofing
Where are you located? "Cold-set" asphalt adhesive has a lot of positives. One of the benefits is that you can apply it year round so you don't have to worry about weather conditions. I think cold-set is the way most people are heading towards anyways because its allows more staging any planning control, odor control, and is less of a fire hazard.
A good site to check out more information on roofing if you plan to do it yourself is http://www.roofingwindows.net
TreB
Trevino.B is offline   Reply With Quote
Old 10-13-2010, 08:46 PM   #3
The cold set adhesives they may be refering to may be the type used in the cold application of sbs(torchon).This is used instead of torching the product.That is what I think of anyways when I hear cold-set.
johnk is offline   Reply With Quote
Old 10-14-2010, 12:31 AM   #4
Rewards Points: 682
I bought 'Henry 203 roof adhesive'. A couple of people told me this was the product to use with roll roofing.
It isn't what I expected. It's supposed to be rather thin, you can put it on with a brush. I was expected the usual thick sticky stuff.
Is this the correct product? Also can it seal out water? I'm thinking of putting a joint where it will have to handle a lot of drainage (no choice, patching up an old crazy roof).
Old 10-14-2010, 12:48 AM   #5
What are you roofing?If its a shed or garage or similiar I would go with a self adhered membrane.Its a way better product,more expensive and diy friendly.Regular 90# mineral surfaced rolled roofing is garbage in my opinion. http://www.certainteed.com/products/...adhered/308479 Many other manufacturers carry similiar products,this will just give you an idea..and also it is a good product
Old 10-14-2010, 12:49 AM   #6
I think what you are looking for is called lap cement.
Asphalt patch/fill/seal with concrete involved brokenknees Building & Construction 1 10-29-2010 03:30 AM
Asphalt Driveway Cold Patch and Sealing DIYguy2000 General DIY Discussions 3 10-29-2010 02:30 AM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 05:58 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 09:05 AM
