What Can Make A Roof Slump On One Side? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-12-2008, 10:40 PM   #1
What can make a roof slump on one side?
I was considering putting a bid on a repossed home in my town. When I got home and looked at the photos I took of it I noticed the roof was crooked. I was going to have the holes in the walls fixed and use it as a rental, but if this is indicative of a major structural problem then I wont even put in a bid. I was going to have it inspected by a professional if I did put in a bid and it was accepted, but if I know this house has a major problem now I could save myself $300.
I hopefully attached the photo correctly. It shows that a section of the front roof has dropped about 4 inches. I didn't notice any sag in the foundation. Could the trusses have broken and caused the roof to tilt?
Should I waste my time with this house?
clueless88 is offline   Reply With Quote
Old 07-12-2008, 11:20 PM   #2
Rewards Points: 6,652
As posted on your other post, it appears to be a sloppy Siding job, but the only way that you can tell if the roof trusses have shifted, is by poking your head into the ceiling in that section.
Old 07-13-2008, 12:35 AM   #3
Looks to me like a addition,maybe just sloppy framing,etc.I'd put in a bid( on conditions that it passed inspection)
johnk is offline   Reply With Quote
Old 07-13-2008, 11:55 AM   #4
Thank you guys. I will do what you suggested.
Thanks!
Old 07-13-2008, 04:58 PM   #5
Hard to say for sure just from the photo with only a frontal view, but it looks like the siding installer just cut those bottom rows too short creating that optical illusion.
Ed
Ed the Roofer is offline   Reply With Quote
Old 07-14-2008, 07:22 AM   #6
747
registered
747's Avatar
Rewards Points: 534
I have never seen anything like that before. Now it could have been just a sloppy framing and siding. But that doesn't mean any structure problems. Get a good home inspector in there. If he gives green lite i say put a bid in go low lookin to clean up. The roof looks good. It would make a good rental property assuming you can get it cheap.
747 is offline   Reply With Quote
Old 07-15-2008, 12:13 AM   #7
the roofing god's Avatar
Send a message via MSN to the roofing god
the panels above are straight and to the roof,probably removed and cut those panels when the roof was done,structure definitely seems straight to me
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 07-17-2008, 02:56 PM   #8
Rewards Points: 518
Throw a level up on the fascia board, it'll tell you how bad its off. Do some measurements from the bottom row of siding up, etc.
n0c7 is offline   Reply With Quote
Ventilating Roof with no ridge? NateHanson Roofing/Siding 7 12-30-2007 05:33 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
flat roof leak snikda9 Roofing/Siding 16 01-26-2006 05:25 PM
New roof on top of new roof? araws Roofing/Siding 4 12-07-2005 07:49 PM
