What Adhesive? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-22-2013, 03:04 PM   #1
Rewards Points: 81
What adhesive?
I thought I needed a new roof but it turns out the cause of my leaking is this.
What sealant is best to stop water from getting under the roofing material? I believe the drip cap is aluminum. Will polyurethane work or an epoxy like pc-11? Thanks.
r1racer is offline   Reply With Quote
Old 09-22-2013, 03:19 PM   #2
Rewards Points: 13,300
Well lets see, the shingle do not have enough over hang, the fascia's all rotted out and needs replacing.
With that poor a roofing job I'd also be looking to see if they even installed a starter strip under the first row of shingles.
No caulking is going to "fix" what's wrong with that roof.
Old 09-22-2013, 04:35 PM   #3
Rewards Points: 81
It's a rolled roof with an integrated gutter system. If I can find something to seal between the drip cap(integrated gutter system) the leaks into soffits will stop. This one area has wood damage because the lip is no longer bonded to drip cap. The fascia is fine (paint was stripped) as I am the middle of painting.
Old 09-22-2013, 04:49 PM   #4
Rewards Points: 81
More pics...can you recommend a sealant? Don't know what was on there before but the rest of the house is fine (for now). I just need something that will give me a little more time before everything is replaced. I am not looking for something permanent and perfect.
Old 09-23-2013, 10:10 AM   #5
Not going to like it, but that's ok.
That whole roof and gutter system was a very bad idea to begin with.
Someone was trying to get out of a new roof as cheap as possible.
That type roll roofing is the cheapest shortest lasting roofing you can buy.
That guttering is going to leak and fail 100% of the time.
Over the years we have seen dozen of that style gutters on this site and any DIY site.
All just caused more damage then good.
Old 09-23-2013, 10:32 AM   #6
Rewards Points: 81
PC-11, epoxy or something else?
Old 09-23-2013, 12:16 PM   #7
Rewards Points: 252
Yeah, that gutter system is just a poor design. I can't tell whether that is rolled roofing or Modified Bitumen.
Sealant really depends on what you have access to locally. You want to look for a high grade asphalt based sealant that is 'rubberized', 'rubber polymer modified', or 'SBS compatible'. Just don't use plastic roofing cement.
shazapple is offline   Reply With Quote
Old 09-23-2013, 12:32 PM   #8
Rewards Points: 81
Will red devil roof sealant work? Or can you recommend a specific item? Thanks again.
Old 09-23-2013, 01:56 PM   #9
Rewards Points: 252
I think so, although it's hard to find info on it from the internet. Henry/Bakor has an excellent website http://henry.com/roofing/roofrepair
Old 09-23-2013, 06:57 PM   #10
Metal Roofing
Rewards Points: 600
Thats quite a situation you got there.
Sure you can caulk it, keep it real handy because you will need that caulking a lot. Caulking on this is a temp bandaide at best.
I agree with Joe. The solution is to do a new roof and eliminate the gutter detail. Ditch the rolled roofing entirely and put a better roof system on.
AndyWRS is offline   Reply With Quote
Hardwood floor adhesive removal Rollotamasi Flooring 1 04-09-2013 01:20 AM
linoleum and adhesive removal, tile after dave.vp Flooring 0 11-15-2012 12:58 PM
Wrong adhesive? Smudgeboss Flooring 0 12-30-2011 07:21 PM
Basement Flooring Question - Cutback Adhesive Atskodinski Flooring 5 12-11-2010 02:48 PM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 05:58 PM
