-   -   wet chimney inside the house... (http://www.diychatroom.com/f9/wet-chimney-inside-house-101519/)
sobro 04-14-2011 02:54 PM
Hi!
I have been experiencing a damp chimney inside my house. The chimney runs through the center (it's a duplex) up through the pantry in the kitchen. I have had the chimney flashing redone (just about a week ago). Unfortunately, it is still damp and I can't do any repairs yet.
So here are my questions:
1. how long should it take for all of the water to exit the bricks and mortar assuming that it could have been saturated before the new flashing was installed?
2. Could there be any other source of water infiltration? I was told that it could be the flue gases condensing in the attic (it's not very well insulated) and then making the chimney damp. Or, possibly something else????
Thanks!
Clutchcargo 04-14-2011 02:56 PM
63 Attachment(s)
Is there a chimney cap on it?
sobro 04-14-2011 03:01 PM
yes - there are two caps . Plus it has two liners (clay?). Both appear to be in very good shape.
seeyou 04-14-2011 04:03 PM
It might take a month or two, assuming you have plaster on brick. Getting the humidity down in the house (running the A/C or a de-humidifier) would help.
The flue gas theory is probably not valid in a lined chimney. It could be an issue in an unlined chimney.
Look at the wash/crown on the top of the chimney. If there are any cracks or a gap around the flue liner, seal them. Water could be entering the mass of the chimney through any breaches at the top. Any water that gets in there will bypass the flashing.
