Wavy Shingles/buckles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-14-2010, 04:32 PM   #1
wavy shingles/buckles
i had my shake roof taken off and new roof put on in winter 4 months ago. only a few weeks ago this stated to show up. in winter here near sacramento, ca we get cold days about 30 degrees and rain on and off. when stepping on the area that are raised it goes down very easy and then slightly comes up again. is it possible that during our 110 degree heat we get in the summer, the shingles will lay flatter or is this something i should tell the roofer to fix right now?
amandalc04 is offline   Reply With Quote
Old 03-14-2010, 05:14 PM   #2
kwikfishron's Avatar
Rewards Points: 1,006
It looks like you need the heat to seal the tabs down. There are a couple of things the roofer could do now. I'd call him and let him know. It could become a way bigger problem if you get some big winds befor that Sac. heat.
They did sheet the roof with plywood over the the top of the skip sheeting befor they installed the roofing? I hope.
kwikfishron is online now   Reply With Quote
Old 03-14-2010, 05:19 PM   #3
as opposed to eusing the old wood? id think so. could the sun bake this down based on what you see and what i described?
Old 03-15-2010, 01:27 AM   #4
jlhaslip's Avatar
Rewards Points: 2,882
any cracked drywall inside the house?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-15-2010, 11:09 AM   #5
not that i know of why?
Old 03-15-2010, 01:56 PM   #6
Residential Roofer
Slyfox's Avatar
Looks like they may have shingled over top of wrinkled felt paper,
I would call the roofer back and ask him about it.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 03-15-2010, 08:52 PM   #7
That was my thought looking at it, but from intuition, not experience. Any idea what kind of felt or underlayment was used?
echase is offline   Reply With Quote
Old 03-15-2010, 08:56 PM   #8
the contract said it was 30lb felt and he also told me that. also, the roof laid completely flat the first 3 months or so, the waves only started a few weeks ago. im hoping by mid summer ill notice a big improvement
Old 03-18-2010, 11:13 PM   #9
has anyone used a roller before in situations like this?
Old 03-19-2010, 09:06 AM   #10
Commercial Roofing
AaronB's Avatar
My guess is wrinkled felt... and it will most likely not ever lay flat
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 03-19-2010, 07:00 PM   #11
roofer came by..roller kinda flattened roof but didnt totally fix it. he lifted shingles on a cooler area, pulled out nails, and sure enough there was the buckled felt. he sliced it with razor and layed shingled back down and its flat. hes going to come by next week to take care of the front of the house in morning when its colder
Old 03-19-2010, 07:08 PM   #12
either thats a strange design shingle or they did a crap job with layout and install. are they supposed to run like that, not the felt problems just the running layers.
The older I get the better I was
Old 03-19-2010, 07:26 PM   #13
its a 3 dimensional shingle so yes, and the waves create a more irregular look at the moment
Wavy hardwood floor RetiredSoldier Flooring 26 01-24-2010 12:46 AM
New Home - Wavy Drywall Seams Repair ?'s bmmitche Drywall & Plaster 2 07-19-2009 04:28 AM
Wavy taping seams - Help (drywall taping) newbpainter Drywall & Plaster 10 05-15-2009 09:36 AM
Wavy Subfloors and Flooring Choices jasonb Flooring 14 12-20-2007 08:22 AM
wavy subfloor problem baltimore Flooring 1 08-24-2006 10:38 PM
