Wavy Roof! Need Opinions/advice - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-02-2012, 05:57 AM   #121
In your two last pics the roof is mostly on and it looks ok. No problems. It also shows they used propavent (sp?). Not my favorite method, but it should be breathing enough to prevent major moisture issues. Dd they use an interior vapor barrier like poly on the inside of the walls, or is it just Kraft paper on the fiberglass.
Morning Wood is offline   Reply With Quote
Old 02-02-2012, 06:32 AM   #122
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Originally Posted by stickner
You said: "It's rather obvious there is a problem with the ventilation and/or insulation, and /or the vapor barrier."
When I crawl up in my attic today, I will take some pics for you and post them. Anything specific you want me to look for? I looked through my pics, and this is the only one I have that shows ventilation example.
What the...why has sheetrock between ripped-off on a new home?
I sure wish I was a fly on the wall from the beginning of construction to today.
titanoman is offline   Reply With Quote
Old 02-02-2012, 06:59 AM   #123
That's probably an area where the roof leaked and they pulled sheetrock and insulation to dry it out.
Old 02-02-2012, 04:37 PM   #124
KemoSabe
loneframer's Avatar
One question that should have been addressed is, at what point in time was this issue noticed?
We're all speculating without this important piece of the story. If the problem didn't surface until construction was complete, MJW is most likely correct in the ventilation theory. If it was noticeable before insulation, that's a different colored horse.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 02-02-2012, 05:27 PM   #125
Rewards Points: 528
Lone, i think that there will have to be some removal of roofing to determine the exact problem
framer52 is offline   Reply With Quote
Old 02-02-2012, 06:14 PM   #126
MJW
The more that unfolds here, the more we have to rethink...it seems.
Interesting to say the least....
MJW is offline   Reply With Quote
Old 02-02-2012, 06:45 PM   #127
Rewards Points: 77
I don't believe there is any poly on the inside of the walls. I am 99% sure of this.
Here are some pics of the attic:
Wavy roof! Need opinions/advice-attic-1.jpg   Wavy roof! Need opinions/advice-attic-2.jpg   Wavy roof! Need opinions/advice-attic-3.jpg   Wavy roof! Need opinions/advice-attic-4.jpg   Wavy roof! Need opinions/advice-attic-5.jpg
Wavy roof! Need opinions/advice-attic-6.jpg
stickner is offline   Reply With Quote
Old 02-02-2012, 06:48 PM   #128
Rewards Points: 77
That was when we had the major water leak.. they had to tear out all the sheetrock, and replace all the insulation. They let the house dry out for 3 weeks. Also brought in a mold remediation expert and extensive testing was done, including air quality testing.
We had to fight them on making this right, but they eventually did do things our way.
Old 02-02-2012, 06:54 PM   #129
KemoSabe
loneframer's Avatar
I agree entirely. I'd rip a few squares myself at no charge just to get a look-see.
Old 02-02-2012, 06:54 PM   #130
Rewards Points: 528
7/16 osb is the material
Looks like you either have bad osb or bad installation, either way you need to get an engineer involved, unless your builder will agree to dissect a portion of the roof to determine the problem.
Old 02-02-2012, 06:55 PM   #131
Rewards Points: 528
Can we get a paid trip to Kentucky?
Old 02-02-2012, 07:03 PM   #132
Rewards Points: 77
It was noticed at the tail end of October. But looking back through th epics, I can see it in some of them.
The felt paper went on around 8/5 or 8/6. The shingles were put on sometime between 8/7 and 8/10.
This is a pic of the roof on 8/20. On the far left side, you can definitely see the outlines of each 4x8 sheet.
The house was definitely NOT INSULATED at this point and you can see the outlines in the roof.
Wavy roof! Need opinions/advice-prefinish-2.jpg
Old 02-02-2012, 07:05 PM   #133
Rewards Points: 77
Another pic from 8/20 - just a bit zoomed in
Wavy roof! Need opinions/advice-prefinish-3.jpg
Old 02-02-2012, 07:08 PM   #134
Rewards Points: 77
This is what our builder said they are going to "eventually" get around to doing... They said, and I quote:
"the roof evaluation will take place when it is 80 degrees plus for a few days"
I asked why they had to wait until it was consistently that warm just to do an EVALUATION.... They said:
"Because of the inconsistency of the wintertime weather pattern"
Old 02-02-2012, 07:09 PM   #135
Rewards Points: 77
You can, but we are in TN!!!
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 12:19 AM
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 12:12 AM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 05:48 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 09:07 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
