Wavy Roof! Need Opinions/advice - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-12-2012, 02:15 PM   #196
Rewards Points: 77
A picture of one of the other roofs a few doors down from us... They all look like this. I felt kinda creepy taking pics of the neighbors houses, otherwise I would have walked around and snapped pictures of them all!
The other pic is from a house that we can see from our backyard that is currently under construction.
What I find amusing is that the builder told us they can't even come out to INSPECT our roof until the temperature is CONSISTENTLY in the 80's!!! Yet, it has been in the 30's and 40's here and they are putting up a roof on a new build...
Wavy roof! Need opinions/advice-otherhouse.jpg   Wavy roof! Need opinions/advice-underconst.jpg
stickner is offline   Reply With Quote
Old 02-12-2012, 02:43 PM   #197
You 're second photo reveals another possibilty. felt paper. Although wrinkled felt normally is a more random lump pattern I have seen this condition. If you can reach one push down with your hand ,if it moves fairly easily it could be the felt.Lumpy felt sometimes flattens with increased temps ,although,they may return when temps change.Maybe thats what your builders waiting for.Or his one year warranty to expire.
roofscum is offline   Reply With Quote
Old 02-12-2012, 02:44 PM   #198
Rewards Points: 528
That felt has to be removed before roofing or the roof will look horrible.
framer52 is offline   Reply With Quote
Old 02-12-2012, 02:45 PM   #199
Framing Contractor
Rewards Points: 118
I have never used the product that you have on your roof. I looked at all the pics, and I don't think the problem was with the carpenters. It looks to be a defect of the product. Seems like others near you are having similar issues.
sixeightten is offline   Reply With Quote
Old 02-12-2012, 02:57 PM   #200
Rewards Points: 77
Look at post 101 of this thread. It is a picture of my roof with just the felt paper on it. You can see it is nice and smooth.
Old 02-12-2012, 03:05 PM   #201
Rewards Points: 77
Also - this roof was put down in early August in Eastern Tennessee. It was 90+ then, and it stayed 80+ for quite some time afterwards (months). I am sure it was warm enough for long enough to flatten out whatever was going to flatten out.
Old 02-13-2012, 10:58 AM   #202
Registered User
Rewards Points: 5,482
I can't remember your attic venting situation, sorry. The paper could be forced to bubble because the exhaust vents are inadequate. The attic space could be under constant positive pressure.This could be from forced or natural pressure called the "stack effect". http://www.wag-aic.org/1999/WAG_99_baker.pdf
Was the attic air sealed before insulation?
Do you have any HVAC units or ducting in the attic?
Is the exhaust/intake ventilation system balanced, or exhaust slightly more?
Gary
Old 02-13-2012, 12:51 PM   #203
Is it just me or in the pic with just the felt down, can you see every rafter telescoping through the felt. It looks like parallel lines from eave to ridge. Could that foil sheathing be cooking that felt and swelling it and the rafters are acting as heatsinks to suck it down? That's the sickest thing I have ever seen. It was 16F here in TN this morning, did your roof look any different with it this cold.?
joeh20 is offline   Reply With Quote
Old 02-13-2012, 04:12 PM   #204
I am very Have sticked framed alot of houses. Two things that are causing this to happens their should be at least 5/8 tongue and grove 4x8 sheathing on this roof. I use that on all my houses that have long rafter runs. It far better job. Rafter should be crowned and Poor quaility lumber should be put aside and sent back. There are always going to be some slight imperfections in lumber. In some cases we had to take out an electric planer and take down high spots.
roofguy is offline   Reply With Quote
Old 02-13-2012, 05:30 PM   #205
Framing Contractor
Rewards Points: 118
Nobody is putting 5/8 t&g on roofs anymore. If you need a stronger roof, use bigger rafters. Using different sheathing to increase strength is backward thinking.
Old 02-13-2012, 07:16 PM   #206
Rewards Points: 77
Our roof looks exactly the same whether it is 16 or 96.
Not sure how that foil sheathing would be cooking anything on that home that is under construction. The highs have only been in the mid 30's to mid 40's the past 5 or 6 days (since they decked and felted it).
Old 02-13-2012, 07:24 PM   #207
Rewards Points: 77
Gary
Look at post 132 and 133 of this thread. That is a pic of the house very shortly after the roof was put on. The interior of the house is still completely wide open at this point. There is no HVAC at all at this point. Not even sheetrock. Just a wide-open house with every stud visible.
To answer a few of your questions:
There are duct lines that run through the attic. There is a heat pump on the second floor. It is located in a large storage/closet area.
The HVAC system is a mess. We have had several companies come in and we basically need an entirely new HVAC system (2 new units and all new duct-work).
Check out my HVAC thread to read all about that fiasco:
Major pressurization issue
Old 02-14-2012, 09:38 AM   #208
Tom Struble's Avatar
Rewards Points: 2,002
the foil facing only works as a radiant barrier only ''if'' it is facing an air space
it can't cook anything
Tom Struble is offline   Reply With Quote
Old 02-14-2012, 05:35 PM   #209
firehawkmph's Avatar
Rewards Points: 1,864
68,
I've never seen anyone around here use t&g anything on the roofs. I do use 5/8" cdx though on my jobs.
Mike Hawkins
firehawkmph is offline   Reply With Quote
The Following User Says Thank You to firehawkmph For This Useful Post:
kwikfishron (02-14-2012)
Old 02-18-2012, 03:10 PM   #210
Rewards Points: 3,256
Originally Posted by loneframer View Post
I was on a roof today that showed signs of horizontal seam ridging. I saw it from the ground and decided to check it out. Much to my surprise, the ridges appeared to be nothing more than buckling of the roofing itself, not the sheathing. The bulge was hollow undeneath and could be pressed down flat.
Here's my theory.
I know for fact that the sheathing was gapped. It is 3/4" T&G with no clips.
Roofing shingles get nailed above the exposure line which results in a second row of nails near the top of the coarse below it. When these two rows of nails span the seam and the sheets expand to take up the gap, they push toward each other resulting in the buckle.
I'm not saying this is the case in your situation, but thought I'd throw it in the ring.
This is an interesting theory as I'm seeing very defined horizontal lines but I can't place the 8' dimension with any consistency. Is this something that will eventually smooth out with heat?
zappa is offline   Reply With Quote
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 12:19 AM
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 12:12 AM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 05:48 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 09:07 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
