Wavy Roof! Need Opinions/advice - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-21-2012, 04:21 PM   #1
Rewards Points: 77
Wavy roof! Need opinions/advice
Hey all - we just has a new home constructed and are having some "issues" with the roof.
There are many noticeable humps and bumps in the roof. After a lot of research, we *think* that the problem is with the rafters.
Specifically, we think that the rafters may be installed with some crown side up and others crown side down. This is causing a "wavy" appearance. Assuming this is what is going on, 2 questions :
  1. What are the dangers of having some rafters crown up and others crown down?
  2. How can this be fixed (I am afraid I already know the answer to this)
If you have any other thoughts on what might be causing this, I am all ears!
Thanks,
Stickner
Wavy roof! Need opinions/advice-01.jpg
Last edited by stickner; 01-30-2012 at 11:12 PM. Reason: update to show one of the pics that was added later in the thread...
stickner is offline   Reply With Quote
Old 01-21-2012, 04:25 PM   #2
Thanks,
Stickner
any picture of the roof?
Hardway is offline   Reply With Quote
Old 01-21-2012, 04:31 PM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
They probably used 7/16" osb over trusses (that rarely sag) spanned 24", as it's the cheapest way to build.
It's normal for the sheeting to sag a little between the trusses.
And it really stands out when there's frost on the roof, as the trusses are the last to melt due to density.
titanoman is offline   Reply With Quote
Old 01-21-2012, 04:31 PM   #4
Rewards Points: 77
Here are some pictures, but pictures aside, what do you think the dangers are of having some rafters crown up, and other rafters crown down?
Wavy roof! Need opinions/advice-roof.jpg
Old 01-21-2012, 04:33 PM   #5
ParagonEx's Avatar
Rewards Points: 150
There aren't really any major dangers. That is the result of laziness from the framers.
ParagonEx is offline   Reply With Quote
Old 01-21-2012, 04:35 PM   #6
Disabled wood vet
titanoman's Avatar
Well, since seeing the pictures...
Are these trusses or rafters?
There's no danger even though the board is slightly weaker, just really looks bad.
Old 01-21-2012, 04:37 PM   #7
Rewards Points: 77
They used solarboard (an OSB product)
http://www.solarbordosb.com/
Here is a pic from when it was under construction.
Wavy roof! Need opinions/advice-img_5124.jpg
Old 01-21-2012, 04:39 PM   #8
Disabled wood vet
titanoman's Avatar
Never heard of such a thing. Must be new within the last 10 years.
Don't like the way they frame any of that either.
Not very good carpenters at all.
Must have been piecework.
Old 01-21-2012, 04:41 PM   #9
Content removed by writer. I don't have knowledge of this type of construction
Old 01-21-2012, 04:48 PM   #10
I don't like this construction all ready and know nothing about it!
Old 01-21-2012, 04:50 PM   #11
Disabled wood vet
titanoman's Avatar
It's called a stick-framed California.
Old 01-21-2012, 04:59 PM   #12
Rewards Points: 77
More pics from when it was under construction.
Wavy roof! Need opinions/advice-img_2050.jpg   Wavy roof! Need opinions/advice-img_2075.jpg   Wavy roof! Need opinions/advice-img_2076.jpg   Wavy roof! Need opinions/advice-img_5088.jpg   Wavy roof! Need opinions/advice-img_5112.jpg
Wavy roof! Need opinions/advice-img_5114.jpg
Old 01-21-2012, 05:03 PM   #13
Rewards Points: 77
So here is the real question... Is it bad enough to force the builder to fix it so it doesn't look bad? And I assume trying to fix this problem would be a MAJOR undertaking?
What would you do if it was your house? Do you think I am right with guessing that some rafters are crown up, and others are crown down and that is causing the waviness?
Old 01-21-2012, 05:11 PM   #14
Disabled wood vet
titanoman's Avatar
The drywall will look just like the roof in that vault.
It may not be an upside-down crown either; some of them may just be crowned more than the others. Those should have been called out, not used.
I don't know where the "splitting hairs" would be; I would definitely bring this to the sellers attention.
Old 01-21-2012, 05:16 PM   #15
Rewards Points: 77
What do you mean when you say "I don't know where the splitting of hairs would be"?
Also - this is my home - I am the buyer of this house.
low slope roof want stop leaking kaju Roofing/Siding 22 09-14-2012 01:19 AM
EPDM - flat roof to sloped roof transition emtaboy Roofing/Siding 12 07-14-2010 01:12 AM
Tying new roof into old. Clutchcargo Roofing/Siding 15 11-07-2009 06:48 PM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 10:07 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
