-   -   Wavy roof! Need opinions/advice (http://www.diychatroom.com/f9/wavy-roof-need-opinions-advice-130881/)
stickner 01-21-2012 04:21 PM
1 Attachment(s)
Hey all - we just has a new home constructed and are having some "issues" with the roof.
There are many noticeable humps and bumps in the roof. After a lot of research, we *think* that the problem is with the rafters.
Specifically, we think that the rafters may be installed with some crown side up and others crown side down. This is causing a "wavy" appearance. Assuming this is what is going on, 2 questions :
  1. What are the dangers of having some rafters crown up and others crown down?
  2. How can this be fixed (I am afraid I already know the answer to this)
If you have any other thoughts on what might be causing this, I am all ears!
Thanks,
Stickner
Hardway 01-21-2012 04:25 PM
Thanks,
Stickner
any picture of the roof?
titanoman 01-21-2012 04:31 PM
They probably used 7/16" osb over trusses (that rarely sag) spanned 24", as it's the cheapest way to build.
It's normal for the sheeting to sag a little between the trusses.
And it really stands out when there's frost on the roof, as the trusses are the last to melt due to density.
stickner 01-21-2012 04:31 PM
1 Attachment(s)
Here are some pictures, but pictures aside, what do you think the dangers are of having some rafters crown up, and other rafters crown down?
ParagonEx 01-21-2012 04:33 PM
There aren't really any major dangers. That is the result of laziness from the framers.
titanoman 01-21-2012 04:35 PM
Well, since seeing the pictures...
Are these trusses or rafters?
There's no danger even though the board is slightly weaker, just really looks bad.
stickner 01-21-2012 04:37 PM
1 Attachment(s)
They used solarboard (an OSB product)
http://www.solarbordosb.com/
Here is a pic from when it was under construction.
titanoman 01-21-2012 04:39 PM
Never heard of such a thing. Must be new within the last 10 years.
Don't like the way they frame any of that either.
Not very good carpenters at all.
Must have been piecework.
Hardway 01-21-2012 04:41 PM
Content removed by writer. I don't have knowledge of this type of construction
Hardway 01-21-2012 04:48 PM
I don't like this construction all ready and know nothing about it!
titanoman 01-21-2012 04:50 PM
It's called a stick-framed California.
stickner 01-21-2012 04:59 PM
6 Attachment(s)
More pics from when it was under construction.
stickner 01-21-2012 05:03 PM
So here is the real question... Is it bad enough to force the builder to fix it so it doesn't look bad? And I assume trying to fix this problem would be a MAJOR undertaking?
What would you do if it was your house? Do you think I am right with guessing that some rafters are crown up, and others are crown down and that is causing the waviness?
titanoman 01-21-2012 05:11 PM
The drywall will look just like the roof in that vault.
It may not be an upside-down crown either; some of them may just be crowned more than the others. Those should have been called out, not used.
I don't know where the "splitting hairs" would be; I would definitely bring this to the sellers attention.
stickner 01-21-2012 05:16 PM
What do you mean when you say "I don't know where the splitting of hairs would be"?
Also - this is my home - I am the buyer of this house.
