Waterproof Deck - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-07-2013, 09:33 AM   #1
Waterproof deck
Waterproof deck
Gerry Hendry is offline   Reply With Quote
Old 09-07-2013, 09:59 AM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
wow thats a really informative post.. thanks
woodworkbykirk is offline   Reply With Quote
Old 09-07-2013, 11:00 AM   #3
Roofmaster
Rewards Points: 2,210
This is what is known as the "Command Voice" when writing specifications.
Part 3 EXECUTION:
Spread adhesive with notched trowel
Generally less is more, in this case its downright cryptic
Old 09-07-2013, 05:03 PM   #4
Waterproof deck
Originally Posted by Gerry Hendry View Post
Waterproof deck
Any ideas as to how to keep water from coming through deck into our carport which is underneath?
Old 09-07-2013, 06:56 PM   #5
Roofmaster
Thats Better.
Yes, Install a fully adhered low slope (waterproof) roof system above the carport with a properly designed structural deck, then install sleepers and a deck system above the membrane roof. Rail details should be round so they can be wrapped, and counterflashed.
EPDM or PVC will work. So will BUR or Modified but flashing will be a bit more involved. Small job, so if EPDM strip in seams. install blow-out patches on all T and 4 way joints.
The Following User Says Thank You to jagans For This Useful Post:
Gerry Hendry (09-07-2013)
Old 09-07-2013, 07:19 PM   #6
What membrane type do you suggest?
Old 09-07-2013, 07:44 PM   #7
Roofmaster
My Personal favorites for this type of project would be Fibertite, or Sarnafil. Very good thermoplastic membranes with a very long history of performance. The benefit to a heat welded membrane is how they lend themselves very well to flashing details.
You will need a manufacturer approved commercial contractor, and it will not be cheap, but it will probably be done right IF you have the right details.
You can use EPDM too, and the contractor base is much larger, and there are some residential guys that do EPDM but you asked, so I answered. I like Firestone EPDM because it is pretty clean (Talc free) right off the roll because they have a very large production facility with huge curing racks.
Success is truly in the detailing with low slope roofing.
All three of these membranes are good, proven products, and any warranty you get on the material should be secondary. You need a good, experienced low slope contractor and a good design for success. Not a piece of paper with a gold scalloped design around the edges.
Gerry Hendry (09-08-2013)
Proper waterproof deck over garage mmerkes Building & Construction 1 08-26-2013 08:37 PM
Cedar deck help mickbiv Painting 11 08-08-2013 09:21 PM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 12:28 AM
who to waterproof concrete roof deck flitz Flooring 1 02-27-2010 08:40 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
