Water Puddle At Base Of Chimney - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-10-2011, 03:08 PM   #1
Rewards Points: 14
Water puddle at base of chimney
Hi,
Any suggestions on how to remedy the below issue? Seems like rain water is flowing down the chimney and causing a puddle right next to the foundation base. Excuse the image quality, it was raining and I took the picture from inside, the puddle is larger around front of chimney base.
Thanks,
Limeybstrd is offline   Reply With Quote
Old 07-10-2011, 07:47 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Rasie the ground level there. Unless it's a wood chimney.
tinner666 is offline   Reply With Quote
Old 07-11-2011, 06:18 AM   #3
Roofer
Roofing Expert's Avatar
... Otherwise break out a shovel and dig a small ditch along and around the chimney footing (8-12" deep by 10-12" wide) and leading away from the area (about 3-5 feet). Then install a plastic perforated drain tile in the ditch and line the sides of the ditch with pea gravel. Cover the drain tile with dirt/sod (or mulch as seen in illustration) and the issue should be resolved
Roofing Expert is offline   Reply With Quote
Old 07-11-2011, 08:16 AM   #4
Rewards Points: 14
Thanks for the advice guys.
I forgot to mention that I had already removed the excess mulch from around the base of the foundation, basically raked it all back to inspect foundation base. Perhaps doing this has caused this area to puddle now, since I effectively create a ditch maybe? Although putting the mulch back there will hide the puddle wont it? It is all sand there, as is around the permeter of the foundations walls.
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 12:32 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
