Water Just Shooting Over Gutter - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-25-2013, 08:55 PM   #1
Lord of Slums
Rewards Points: 1,974
Water just shooting over gutter
Inside corner under valley. I put a six inch gutter and downspout on. I did not put a splash guard on because in the fall everything fills with leaves so it is pointless. I just put down mulch and to see the water over shooting the gutter and wash my mulch away was sad. Maybe I need to reconsider the splash guard idea, at least until fall. It is too much surface area going to a gutter that is too small length wise. I have never liked the idea of doing anything to the metal valley itself. Such as putting little pieces of flashing to slow down the flow. Now I am open too suggestions. I was wondering if I put a 4 inch why at the bottom of the downspout if that would act as a vent to allow more water too go down faster. I have even thought of laying chain in the valley to slow the water. Is this just one of those no win situations?
mj12 is offline   Reply With Quote
Old 06-25-2013, 09:06 PM   #2
Rewards Points: 644
Splash guard is the best solution if its just blowing past the gutter.
Length of gutter vs roof area doesn't matter, as long as the drains are adequate. For a lot of sf into a single gutter use larger downpipes, 3x4 if your area uses rectangular, or 3.5x3.5 if square.
PatChap is offline   Reply With Quote
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 12:47 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Water Softener shooting water. morgan7c Plumbing 5 01-31-2010 09:23 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
