Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-31-2007, 11:45 AM   #16
Commercial Roofing
AaronB's Avatar
Water in the insulation
You need to vent the attic (making the insulation useless) or install a de-humidifier, or remove the insulation and place new dry insulation on the ceiling.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 01-31-2007, 11:47 AM   #17
Commercial Roofing
AaronB's Avatar
With a monolithic vapor barrier, not a vapor retarder, which slows, but does not stop air infiltraion.
Look into SPF insulation...a complete air stop if installed correctly.
Old 01-31-2007, 02:13 PM   #18
Did you mean to install the dehumidifier temorarily, just to let the insulation to dry up?
I would prefer not to replace insulation or vapor barrier, because it would require to destroy all the walls and ceiling, and it would be a pity.
dpreznik is offline   Reply With Quote
Old 01-31-2007, 02:56 PM   #19
concretemasonry's Avatar
You will not dry out fiberglass with a dumidifier, no matter how long you use it. A dehumidifier is just that - it is not a dryer and does not have enough air flow or provide circulation. This is espeicially true if you have the wall finished or covered.
Even if you take out the insulation, you will be surprised what it takes to really remove the moisture. - Do you have a very long covered closeline with good circulation in an arid climate?
The longer you leave the wet insulation in the wall with wood and cellulose (if you have sheetrock), the better chance to get mold and rot. It happens faster in warm weather and a roof gets warm without ventilation.
concretemasonry is offline   Reply With Quote
Old 01-31-2007, 04:22 PM   #20
Commercial Roofing
AaronB's Avatar
I did not mean to use the de-humidifier to dry out the insulation.
If you cannot access the insulation, how do you know it's wet?
Old 01-31-2007, 04:34 PM   #21
I can access it in a limited area, behind a knee wall. I have a door there. Behind that wall, the insulation is not covered with sheetrock.
Old 02-01-2007, 12:07 AM   #22
Commercial Roofing
AaronB's Avatar
Is this a Cape Cod?
Old 02-01-2007, 06:59 AM   #23
Is this a Cape Cod?
I am sorry, I don't understand the question.
Old 02-01-2007, 08:30 AM   #24
I believe AaronB is asking what style of house do you have.
ie. Cape Code, colonial, ranch, victorian...
redline is offline   Reply With Quote
Old 02-01-2007, 08:52 AM   #25
It is a ranch. It has a cathedral ceiling over the living room, and stairs to an inside balcony over the living room. The balcony leads to the attic over bedrooms, which I turned into a new room.
Old 02-01-2007, 12:16 PM   #26
Commercial Roofing
AaronB's Avatar
If it is, indeed, condensation, instead of a roof leak, then you will probably need to add insulation in order to move the dew point to within the insulation assembly. Then, your warm moist air will not condense on the ceiling cuz there will not be a thermal differential. No cold surface, no condensate.
A de-humidifier to remove heater gas moisture would surely aid in your efforts. I think I would try this first, depending on your climate.
Old 02-01-2007, 12:24 PM   #27
But I have no more space for additional insulation, I installed as much as possible. R49
Do you mean even before installing the ridge vent?
BTW, maybe you know about how much it may cost to install the ridge vent, if the roof is 47 feet long?
Thanks.
Old 02-01-2007, 02:15 PM   #28
Commercial Roofing
AaronB's Avatar
If it is happenening how you say it is, I do not think ridge vent will help the condensation problem, but your roof still needs underside venting.
I would install a shingle-over ridge vent on a walkable ranch 47 feet long for approximately $900.00.
You would still be left with your air exfiltration problem. I think a vapor BARRIER would help immensely, but you would have to do either roof deconstruction, or interior deconstruction.
Old 02-01-2007, 03:13 PM   #29
I used to have vapor barrier, but in the spring, water was condensed between the barrier and retarder, so I removed it before even installing the sheetrock. I guess it would be better to remove the retarder, but now it is too late. I am in desperation.
Old 02-01-2007, 03:40 PM   #30
Commercial Roofing
AaronB's Avatar
Find the source of moisture infiltration and seal it off.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 04:28 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
help Chuckman Off Topic 8 06-15-2006 11:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
