Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-04-2008, 06:44 AM   #1
water and ice barrier question
My parents are in their late 80's and have a roof that has very little slant to it,. plus it a vaulted ceiling inside. They had a new roof put on and because of the pitch of the roof the contractor installed a water and ice barrier product on the Whole Roof.. This spring they had very bad roof leaks from what look like the peak area and below. My question is..If a conctractor installed this water and ice barrier on the Whole Roof, from what I read it shouldn't leak? No matter what? Ice damn, snow and rain?
and is it important or not that if you have a water and ice barrier install should they also install the felt too?
Thank you
2divers is offline   Reply With Quote
Old 11-04-2008, 06:55 AM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
I'm assuming they installed a shingle roof. if so they installed the wrong roof. shingle roofs are not designed for low pitch roofs. it should of been a split sheet or rubber glue down.
could be the leak could be coming in from the apron flashing above. BOB
