Water In Fireplace? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-04-2011, 03:56 PM   #16
Cape Cod, MA
Rewards Points: 81
I posted some pictures. The second time the roofer came by, he put caulking of some sort to seal things up? Im not sure if caulking is supposed to be used to seal flashing? If you look through the cage, you will see cracks that have developed. There are some more cracks but I hit my upload limit.
Water in Fireplace?-front.jpg   Water in Fireplace?-left1.jpg   Water in Fireplace?-left-2.jpg   Water in Fireplace?-right.jpg   Water in Fireplace?-rear.jpg
capecodder is offline   Reply With Quote
Old 12-04-2011, 05:39 PM   #17
Rewards Points: 190
I'm not a roofer so feel free to ignore this, but to me that flashing looks good and if it was leaking I don't think you would have water in the fireplace but on the ceiling in the room below. I see the chimney is covered but could it be wind driven rain coming down the chimney? I have a chimney open to the sky and have had so much rain coming down I had to build a tile dam across the front of the hearth to keep water from pouring out on the wood floor. I have had hail stones bouncing on the hearth.
zircon is offline   Reply With Quote
Old 12-04-2011, 06:04 PM   #18
Cape Cod, MA
Rewards Points: 81
I know the chimney cap isnt right. When I moved in a year ago it had no cap on it. I made one from some galvanized steel stock I had at work. the water comming in is during heavy rain storms. Im also getting water inside the house as if its leaking due to a bad flashing job. Im just not sure if at that pitch I should have a cricket/saddle made up? im wondering if its pooling and overwhealming the flashing.
Old 12-04-2011, 08:02 PM   #19
Doing This Way Too Long
Rewards Points: 532
When was that roof done? It does not look like the flashings are properly stepped with the shingles. If they are all just fastened to the deck and all the shingles go over it then it is not proper and has a potential to leak from the sides.
There is a reason it is called step flashing.
Should have been stepped then counter-flashed.
*edit* Just looked at your first pic and it's a different roof with the same flashings. Pretty sure you need to get someone in there that can properly flash around that thing with something other than caulk
OldNBroken is offline   Reply With Quote
Old 12-04-2011, 11:44 PM   #20
Cape Cod, MA
Rewards Points: 81
I asked the roofer if the flashing needed to be redone to match the roofing shingles and he told me that just the rear needed to be redone. I thought this was strange, but Ive never looked into this until now, now being this past month when my chimney started leaking during heavy rain, leaking into the firebox and leaking behind the flashing. Im very disappointed...#1 at the quality of work that was performed, and #2 at myself due to my poor judgement, I should have done my research on a contractor.
I would like to flash this chimney properly, and I would like to do it myself with the help of you fine gentlemen. Im mechanically inclined and i follow instructions well. I have no problems buying the proper tools for the job (within reason). I plan to do a search on how to flash properly, Ive seen a few video's on youtube. Any links in the proper direction are greatly appriciated.
For starters, I have 2 square of extra roofing material (bought extra for the shed im going to build) so If I need to rip out what is there it shouldnt be a problem. My question so far is...
I need to know if you folks think the roof is steep enough that it would warrant the use of a cricket/saddle on the back side? If i remember correctly the pitch was 7.5 if it matters.
What tools will i need to cut out the mortar between the bricks? I have access to a medium sized dewalt angle grinder, what cutting disk will i need?
Since I have never flashed a chimney before, how does the lead get packed inbetween the bricks and how deep should i cut in?
How does the lead get sealed into the brick? There is a possibility for water to get behind the flashing am I correct?
As far as the chimney crown goes, are the cracks shown enough to warrant leaks into the fireplace or is this most likely wind driven rain?
Once again guys, thanks for the replies and all the help. I wish I found this site before I had my roof replaced.
Old 12-04-2011, 11:56 PM   #21
Rewards Points: 532
One good thing is a chimney that wide does not necessarily need a cricket. A proper pan will do just fine. Yours may be fine but cannot tell with the shingles on. it's your side flashings that are the problem. Actually the existing flashing can be used as a counterflashing if you cut them off about an inch above the roofdeck.
Flashing a chimney is not an easy thing to explain good enough to make sure you do a proper job. Somebody could possibly post some illustrations that may help out.
So if you just had this roof done, don't you have some kind of warranty from the contractor? You never gave us any history on the roof itself.
Old 12-05-2011, 12:10 AM   #22
Cape Cod, MA
Rewards Points: 81
The roof itself was done in may of this year. I do have a warranty but im not exactly happy with the work they have done. The way I look at it is, they are trying to cut corners here. The second time they came up, they added caulking to try to "seal things up". From the video I have seen, the side flashing is definatly wrong. The certainteed slate shingles are taller (as in the lenth of the design) vs. the 3 tab shingles that were previously on there, they should have replaced the flashing like I thought they were going to do from the start. When the contractor was here, I asked what will happen if it leaks again. He says he will need to rip out the shingles behind and around the chimney because he feels the problem lies on the back side.
Im not sure what you mean by the proper pan? Im not familiar with the terminology.
You say the chimney is wide and does not need a cricket? I thought the wider the chimney the increased change that it does need a cricket?
Old 12-05-2011, 12:33 AM   #23
Rewards Points: 532
Sorry, guess I should have said "of that width" or better yet "that narrow.
Single-flue chimneys that NARROW do not need a cricket. What you have there is a pan and, if done properly it is just fine.
Contrary to what your roofer says, I doubt the backpan is the problem but the whole thing should be torn up and re-done to make sure.
As far as you doing it yourself, if you attempt any repairs yourself then you "buy" the roof. Any problems in the future and you assume all liability and your "contractor" is off the hook for good.
If this is a legitimate contractor you have legal recourse to have it done correctly on his dime, whether it's him doing the work or him paying for you to find someone to do it correctly. You just have to find out what recourse you have in your state. Generally if you communicate x amount of times and they fail to correct it properly then you can have someone else remedy it and charge him for it.
Old 12-05-2011, 12:42 AM   #24
Cape Cod, MA
Rewards Points: 81
I guess what I should do next is run a garden hose up there to see if the leak is from the flashing itself or from the crown. Do you agree that should be the next course of action?
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
gas fireplace with same vent as furnace & water heater? Van3 HVAC 0 01-30-2011 05:21 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
