Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 02-05-2011, 11:39 AM   #1
Water on fascia
My wife and I purchased our house 3 mos ago. We live in Oregon, so we get a bit of rain. I have noticed that water from the facia, the board on which the gutter is attached - is there an easy solution?
Mabrown is offline   Reply With Quote
Old 02-05-2011, 12:10 PM   #2
Experienced
Jackofall1's Avatar
Water on fascia
Not sure what you are asking here.
More information would be helpful.
Mark
Old 02-05-2011, 12:22 PM   #3
Water on fascia
Mark
How would I Re route the water so it all goes to the gutter instead of leaking on the facia
Old 02-05-2011, 04:15 PM   #4
Water on fascia
Install a drip edge under the shingles and extend inside the gutter?
handy man88 is offline   Reply With Quote
Old 02-05-2011, 05:04 PM   #5
Experienced
Jackofall1's Avatar
Water on fascia
Many times water that flows over the eavestrough onto the facia, is caused by a plugged or undersized down spout.
Mark
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
Low/No Hot Water Pressure after changing Elements Onehipcat Plumbing 18 08-05-2010 10:16 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
