Water Comes In From Bathroom Fan When It Rains. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-06-2011, 09:38 AM   #1
Water comes in from bathroom fan when it rains.
How can I fix the vent so water doesn't come in when it rains. I get so much water that trickles through when it rains that is soaks the shower rug. It has left water marks all over my ceiling. It happens every time it rains and when I pull the cover off the exhaust fan rusty dirty water comes gushing out.
Ashbodash is offline   Reply With Quote
Old 03-06-2011, 10:06 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
I'd start at the source. The roof.
What does it look like up there?
Is the flashing OK?
DM
Old 03-06-2011, 10:14 AM   #3
waterman1971's Avatar
Rewards Points: 150
Please be careful! The risk of electrocution is present every time you touch that fan.
waterman1971 is offline   Reply With Quote
Old 03-06-2011, 11:18 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Should be something like this up there
tcleve4911 is offline   Reply With Quote
Old 03-10-2011, 11:44 AM   #5
Is the flashing OK?
DM
I agree, the problem is going to be on top of the roof. A picture or two from the roof top above the bathroom would really help.
DUN-RITE ROOFING INC.
THE ROOF DOCTOR OF TULSA
dghazelwood is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
