Walking (safely) On A Metal Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-25-2012, 10:53 AM   #1
Gymschu's Avatar
Rewards Points: 488
Walking (safely) on a Metal Roof
As a painter, I have several projects this year which will require walking on metal roofs to get to some areas that need painting. None of these roofs have steep pitches. Are there special shoes that can give me some extra traction? On a side note, I slipped and fell on a metal roof because I didn't see some morning dew on the surface.
Old 02-25-2012, 10:58 AM   #2
Rewards Points: 13,300
Sneaker should work.
I like to use one of these on the ladder.
http://www.badgerladder.com/p.92/roo...oof-hooks.aspx
Gymschu (02-25-2012)
Old 02-25-2012, 11:10 AM   #3
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
If it's a standing seam roof, you can clamp sheet metal vice grips to the seams in several places and lay a 2x4 across the top of them to give you a toe hold.
seeyou is offline   Reply With Quote
The Following 2 Users Say Thank You to seeyou For This Useful Post:
Gymschu (02-25-2012), Tom Struble (02-25-2012)
Old 02-25-2012, 12:21 PM   #4
Gymschu's Avatar
Rewards Points: 488
Joe, Seeyou, thanks for the suggestions.........I'll give both ideas a try.......and upgrade the tread on my sneakers!
I will add that I am a bit timid up on these roofs because when you fall, there's no warning, you go down & you go down HARD!
Old 02-25-2012, 12:53 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,954
Be sure to get something in your contract (in writing) that you will not be responsible for any shoe prints or any other normal foot traffic marks on the roof.
If you damage it, yes...you should be responsible.
That being said, if the finish is beyond serviceable and the surface is very chalked, even light foot traffic will show and you will be on the hook for it.
Just giving you a heads up and you should very carefully inspect the surface prior to walking it.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
Gymschu (02-25-2012), mae-ling (02-26-2012)
venting from mobile home through new metal roof jeanmoon Roofing/Siding 8 05-01-2015 09:53 AM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 04:58 PM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing/Siding 7 06-04-2009 03:58 AM
New Ven Through Existing Metal Roof bmurphywa Roofing/Siding 2 05-20-2009 11:37 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
