"W" Valleys Meet At A Dormer Ridge - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-18-2008, 08:28 PM   #1
"W" valleys meet at a dormer ridge
I am installing a metal panel roof. There is a dormer that connects to the main roof part way up the main roof. I have "W" valleys where the two roofs meet. How do I bring the two valleys and the ridge cap of the dormer and the panel of the main roof together. I have already tried something, and it is not going to cover the small inverted "V" in the center of the "W".
Carlbuc is offline   Reply With Quote
Old 11-19-2008, 01:00 PM   #2
Use sheet lead from a plumbing supply facility. It is malleable but needs to be formed gently with a rubber mallet or the handle of the roofing hammer, so it does not tear.
Alternatively, you can have the W-Valley metal bent so the inverted "V" tapers down to Zero as it gets to the top of the last sheet of valley metal.
Ed
Ed the Roofer is offline   Reply With Quote
Old 11-23-2008, 10:47 AM   #3
Commercial Roofing
AaronB's Avatar
You can cut the metal to lock together and either caulk or solder the seams, depending on what type of metal you are using.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 07-23-2012, 02:18 PM   #4
Rewards Points: 68
joining 2 w-vallies and the metal sheet above
mine I think is about the same question. But having gone to the trouble of taking pictures, I thought I would post my situation anyway.
Am also wondering how to merge 2 w-valleys and cover them with a sheet of roofing steel coming from the ridge above.
"W" valleys meet at a dormer ridge-p1010814.jpg   "W" valleys meet at a dormer ridge-p1010815.jpg   "W" valleys meet at a dormer ridge-p1010816.jpg   "W" valleys meet at a dormer ridge-p1010817.jpg   "W" valleys meet at a dormer ridge-p1010818.jpg
pjstock is offline   Reply With Quote
Old 07-23-2012, 07:44 PM   #5
Join the w valleys together where they meet perfectly. They can be done pretty easily, you may have to make several cuts to get it right. Seal where they join together with caulk, try to make it lap. Your valleys should be watertight at the point. Then your ridge cap can be cut at the same angle at the center of the valley and folded down over the "w".
roofnron is offline   Reply With Quote
The Following User Says Thank You to roofnron For This Useful Post:
Windows on Wash (07-24-2012)
Old 07-23-2012, 07:54 PM   #6
Rewards Points: 68
Nice job!
thanks.
I'll try to emulate that elegant work. (fat chance.)
Old 07-24-2012, 04:23 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,704
Nice work Ron.
Old 07-24-2012, 06:14 AM   #8
Rewards Points: 68
you wouldn't happen to have a detailed picture of how you trimmed and joined the peaks in the w-valleys would you? I am still stumped. (though I expect trial and erroring through a couple of sheets of W-valley I should find a solution.)
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
Useless Ridge Vent? itwerx2 Roofing/Siding 22 10-22-2007 09:57 PM
