Vocal Booth Ceiling - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-23-2013, 09:46 PM   #1
vocal booth ceiling
Hello, I am building a room inside a room, a vocal booth, I need help with the ceiling, it cannot be attached to the existing room, only put on top of the walls. what kind of products/ or building techniques are available in the market to prevent the ceiling from having a "belly" in time... something that will help me build a strong ceiling. (sorry for the non professional language )
If someone can point me in the right direction Thank you!
Hila is offline   Reply With Quote
Old 03-25-2013, 06:05 PM   #2
Rewards Points: 744
This really should be in the 'building and construction' forum, but anyway...
Sheetrock. Or better, quietrock. The building techniques for your decoupled room are the same as normal construction. You need to run some kind of ceiling joists on top of the walls. The Quietrock gets attached to the joists.
As an alternative to a full-on room-within-a-room, have you considered using a resilient channel system (metal hat channel w/ sound-isolation clips)? http://decibeldropadhesive.lamvin.com/
Seattle2k is offline   Reply With Quote
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 04:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 09:27 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 05:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
