-   -   vinyl soffit for roofing (http://www.diychatroom.com/f9/vinyl-soffit-roofing-106201/)
dadob 05-31-2011 09:01 PM
I want a pure white roof. I tried paint but it doesn't look good after a few years. Good vinyl can last a long time. So why can't I put vinyl on my roof? I'm thinking non vented i.e. no holes, vinyl soffit running longways down the roof so the channels will point up and down. I realize I may need to get creative to keep the wind from blowing it off. I think I can solve that problem. I think it will look good, I could even do angles.
So, why can't I do this, why shouldn't I and what will I regret? Have at it. I already know it won't be easy to walk on if I need to do repairs. But I think I can solve that problem. What's else? Thanks.
dadob
handy man88 05-31-2011 09:37 PM
dadob
It'll be interesting how you seal the nail holes used to secure the vinyl onto the roof sheathing. Also, it'll be quite noisy with the flapping and thumping as you can't nail snug against the roof to allow for expansion and contraction.
Why don't you consider a prepainted metal roof.
rossfingal 06-01-2011 08:38 AM
I've been dealing with Vinyl siding/soffit since the mid 1970's.
Also, an estimator/repair/super for a roofing-siding contractor/supplier.
Don't do it!!!!
You'll have nothing but problems!
Consider what "handy man88" advises - metal.
rossfingal
(to add: contrary to popular opinion - I've torn off Vinyl siding that had
been destroyed by "Hail" -that was on the sides of houses - think about
what could happen on a roof!!!)
DangerMouse 06-01-2011 09:06 AM
1 Attachment(s)
I think you should ask someone that has actually done it if it's feasible or not. For a home?...nah.....
So far as a large roof that may need to be walked on for a dwelling, I'd certainly say no way, but for a small shed?
That's a different story altogether. Here's a small shed I did (sides AND roof) 7 years ago with all free vinyl soffit I had laying around. Not one drip inside. I silicone caulked the extra holes I added to make sure it did not blow off easily.
However, as you can see, parked under the wrong tree (It's a trailer with wheels.... moveable storage) will gray it a lot, plus I've never cleaned it..... but dry it is inside! It's been hit with lots of hail too, but not one hole! Maybe I'll go out and run a hot, soapy scrub brush over it to see how white it is underneath the years of basswood haze.
DM
waterman1971 06-01-2011 09:35 AM
DM
I must say that is really neat.
I tip my hat to you :thumbsup:
Tom Struble 06-01-2011 07:57 PM
just to say there is no vinyl siding or trim panel that will be warranted as roofing
Grumpy 06-03-2011 01:32 PM
Don't use paint. Instead use an elastomeric roof coating. use a high grade elastomeric coating, such as RM Lucas or ER Systems.
You can sometimes put vinyl shakes on your roof, depending on pitch. it has to be a really really steep pitch. Why can't you do it? They are NOT engineered to be water tight. Vinyl and aluminum siding are NOT water tight. Remive the vinyl after a heavy rain and the wall behind will be wet. It's the tyvek or similiar weather resistant barrier that keeps the water out, and on a wall the gravity. On a rof you won't have that gravity and each nail hole will LEAK.
Tear off the roof, install a cover board and a white thermoplastic like TPO or PVC. Perhaps install a shingle like the CertainTeed star white.
