Vinyl Siding J Boxes - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-12-2013, 04:18 PM   #1
Rewards Points: 396
vinyl siding j boxes
Those J boxes for exterior outlets in vinyl siding do they go over or under the house wrap right against the sheathing?
detroittigerfan is offline   Reply With Quote
Old 09-12-2013, 05:47 PM   #2
Rewards Points: 12,808
Over. If it makes you feel better use some window tape over the top flange.
Old 09-12-2013, 08:11 PM   #3
Rewards Points: 396
Should you incorporate a drip cap over the j box? Not even sure how you could though.
Old 09-12-2013, 08:51 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
yes tape the flange.. at the top of the jblock cut the house wrap and tuck the tape up under the paper so its properly lapped
woodworkbykirk is offline   Reply With Quote
Old 09-12-2013, 09:18 PM   #5
No drip cap needed.
DIY - Vinyl Siding over Cedar Shakes rebelranger Remodeling 9 08-02-2012 10:47 AM
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 11:23 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
