Vinyl Siding Choices - Roofing/Siding - DIY Home Improvement | DIYChatroom
Closed Thread
Old 03-25-2014, 08:39 PM   #1
Rewards Points: 248
Vinyl siding choices
Just wondering where is a good place to start with choosing a good manufacturer for vinyl siding. Ive installed it once before with a friend on his house, but I never really got into the details .. This is going on my house so I wanna be prepared as best I can when I buy the material... Thanks in advance
timothy300858 is offline
Old 03-25-2014, 08:40 PM   #2
ParagonEx's Avatar
Rewards Points: 150
Depends on your price pint.
My favorite vinyl is Craneboard Insulated Vinyl
ParagonEx is offline
Old 03-25-2014, 09:03 PM   #3
Rewards Points: 12,886
Check out this site. http://www.certainteed.com/products/vinyl-siding
It even has a design center so you can see different types of siding and even colors.
Most people do not do not have a clue about all the available options that can really make a siding job pop, so take the time to look around.
Siding sounds like a simple job to do but by far I've seen more done wrong then right.
I see no point in going with "insulated siding". There's still air gaps at the bottom, ends and butt joint and the price for the siding may well be 3 times as much.
Also going to be paying more for all the trim because it will need to be 1". It can also cause issues around the windows and doors because it sticks out so far.
joecaption is offline
diynewguy (03-25-2014)
Closed Thread
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 11:23 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
