Vinyl Siding? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-13-2014, 06:56 PM   #1
Rewards Points: 150
Vinyl siding?
I am wondering would a box of 200 sq ft of vinyl siding cover a 12x20 single car garage?
CJIII is offline   Reply With Quote
Old 06-13-2014, 07:01 PM   #2
kwikfishron's Avatar
Rewards Points: 86
No... but 3 might.
kwikfishron is offline   Reply With Quote
Old 06-13-2014, 07:05 PM   #3
Rewards Points: 12,818
Sure, if your only doing one side.
It's length X width, plus at least 10% waste.
If one side is 8 X 20 that's 160 sq. ft. for just that one side.
Old 06-13-2014, 07:25 PM   #4
Rewards Points: 150
Ok What about 1x8x12' lap siding?
Old 06-13-2014, 07:29 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Are you here shopping for siding or are you shopping for a fool to do all your estimating for you? Go to your intended supplier and let them do the math.
Depending on eave height which you haven't mentioned and door and window sizes which you haven't mentioned, you may be needing around 600 square feet of material.
XXX
Old 06-13-2014, 07:33 PM   #6
Rewards Points: 86
That doesn't come in boxes.
Do the simple math, length x height = Sf. LxH/2 for a basic gable.
Old 06-13-2014, 07:53 PM   #7
Rewards Points: 150
I do my own estimating.
Old 06-13-2014, 08:19 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So are you in the business?
XXX
Old 06-13-2014, 08:28 PM   #9
JOATMON
ddawg16's Avatar
Rewards Points: 816
To be honest with you, I have a feeling your really bad at estimating if you can't figure out how much siding you need.
ddawg16 is online now   Reply With Quote
Old 06-13-2014, 08:59 PM   #10
Rewards Points: 150
I never really did much siding estimating.
Old 06-13-2014, 09:00 PM   #11
Rewards Points: 150
Nope Bud, I am working for the city of Montgomery.
Old 06-13-2014, 09:45 PM   #12
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good! Don't quit your day job.
XXX
Old 06-13-2014, 10:32 PM   #13
Contractor
Siding estimates arent much different than any other square footage method. Here are the basics.
If the building is 12x20 thats great, but thats just the FOOT PRINT. You need the HEIGHT of the outside walls and length as well. Meaning you need the exterior dimensions of the building, for all the walls. Example. using a round number ---
12 foot wide walls x 10 foot high walls would be 120 square feet. assuming each side is equal then its 120x4 giving you 480 square feet. add 10% for over run and thats an addition 96 square feet.
A total of 576 square feet. Which will translate to 600 Square feet or 6 boxes of siding. Each box has 2 SQUARE of siding.
A SQUARE is 100 square feet.
Now you must measure all doorways and windows to figure out your Linear footage of J Channel. Also you may need starter strip. Outside corner posts and if there are inside corners, inside corners.
steveinNEPA is offline   Reply With Quote
Old 06-13-2014, 10:35 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
......and that doesn't include gable ends depending on the style of roof and the slope.
XXX
Old 06-13-2014, 10:40 PM   #15
Rewards Points: 150
Ok thanks!
Vinyl siding over wood siding snorris1 Building & Construction 29 03-02-2012 11:23 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 08:06 AM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
