Vinyl Perf Soffit Over Wood - No Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-21-2011, 11:59 AM   #16
Originally Posted by jmiller View Post
Did you calculate the needed ventilation for an attic your size? The ridge vent may not need to be continuous to get the minimum exhaust, which solves the problem of lack of room for intake if you can leave some uncut. It's better to have more intake than exhaust, than it is to have 'continuous' ridge vent, so long as you satisfy codes.
The attached image is the suggested (50/50 NFA @ 150) ventilation for my attic space. So this would work. But more is better if available, right? What if I wanted to maximize my full soffit intake area... i.e., run it the full 37' on each side of the house instead of just the 26'. So, instead of 52' of intake I go 72' (almost the entire length). That would of course up the ridge vent length too. Again I have approx. 37' of ridge to work with. So a 30' ridge vent seems to work well...?
Also I figure if I go with the 60/40 vs 50/50...
72' (INTAKE) x 9" NFA = 648" NFA
30' (EXHAUST) x 18" NFA = 540" NFA
648" NFA (approx. 60% soffit)
+ 540" NFA (approx. 40% ridge)
________
= 1188" NFA
That's 9 total pieces of Continuous Soffit Intake Vents - 9 sq.in./foot NFA
(4.5 each side) - OR - 648" NFA / 9 sq.in./foot NFA = 72' / 8' pieces = 9 total vents
I THINK
nickelshine is offline   Reply With Quote
Old 01-21-2011, 12:01 PM   #17
There are many many threads on attic ventilation. Based on pro commentsit sounds like it is very common for roofers and estimators to not be knowledgeable about ventilation.
beerdog is offline   Reply With Quote
Old 01-21-2011, 01:40 PM   #18
Registered User
Rewards Points: 5,520
NS, you need to have soffit vents across every rafter bay to move the heated air with moisture from the rooms below. Otherwise there will be dead air spots that will get condensation on the roof, framing or insulation. The 150/300 rule is an older one, if you ventilate on a 1/100, you are still fine.
Working backward;
37 x 9 int. = 333 / 144" = 2.31 x 2 sides = 4.63 total int. + 4.63 exh. = 9.26 total
37 x 18 exh. = 666 / 144" = 4.625 exh.
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
nickelshine (01-21-2011)
Old 05-29-2012, 09:12 AM   #19
Resolution?
Over the weekend I discovered that our house, built in 1986 and just purchased the week before, has exactly the same problem that nickelshine described: vinyl siding covering solid wood soffit, so no ventilation.
I'm curious to know: did you solve your problem?
rileymango is offline   Reply With Quote
Soffit Vents for Wooden Soffit? rollenrock33 Roofing/Siding 2 12-27-2010 06:16 PM
24" Soffit vents. NickiesHomes Roofing/Siding 2 07-12-2010 05:24 AM
Odd Sized Soffit Vents vball Roofing/Siding 1 09-08-2008 05:18 PM
Missing soffit vents glenn60 Building & Construction 6 04-14-2006 02:25 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
