Venting A Thin Aluminum Soffit - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-02-2013, 08:42 PM   #1
Lord of Slums
Rewards Points: 1,974
venting a thin aluminum soffit
In a future post I will give a good deal of detail. For now, my question is how the heck can I cut a continuous vent into an aluminum soffit? No wood underneath. I am having a terrible time with ice damning. I do not know anything about the insulation, and I do not have a ridge vent. I did not want to put a circle vent into every bay. I did not want to put those 8 by 16 inch vents in. I was looking at these things called stealth soffits , but I did not want to replace the soffit either. I know how to add insulation, seal the air leaks ect, it is just that darn sofitt that is the problem. http://www.rollex.com/products/stealth-soffit
mj12 is offline   Reply With Quote
Old 11-03-2013, 05:30 AM   #2
Rewards Points: 14,306
Post a picture of what you have now.
Is then no venting on the roof at all, not even a gable vent?
Not going to do any good to add soffit vents if there's not some form of venting at the peak of the roof. There would be no way for the hot moist air to get out.
Unless you have a cathedral ceiling there is no need to add vents in a every bay.
A gable vent on each end of the house or ridge vents will work fine.
Going to be a real pain to try and add continuous venting after the fact.
If the soffits are like most I've worked with before they may only be attached on the ends of each piece, some may not even be nailed.
Cut them in half to add the venting and there going to be falling down.
About the only easy DIY way I can think of to add the needed venting is with round snap in vents.
http://www.bing.com/images/search?q=...reen&FORM=IGRE
You will also need to add baffles in the attic to keep the new insulation from blocking the air flow from the soffit vents.
Old 11-03-2013, 07:02 AM   #3
K&B Designer
Live_Oak's Avatar
It's a lot easier to replace it with vented soffit than waste the massive effort attempting to alter what's there. Adding the ridge vent and insulation baffles is the key to making it work though. Ventilation is a system that fails without all of the right components. It doesn't do any good to add one without the other allowing it to work correctly. It's like putting new spark plugs in a car that's out of gas.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
joecaption (11-03-2013)
Venting bathroom fan via soffit spaceman spif HVAC 3 07-29-2012 03:57 PM
Recycle old aluminum soffit and fascia jbjones General DIY Discussions 7 04-17-2011 05:22 AM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 09:15 PM
Help with installing aluminum soffit and fascia Boontucky Roofing/Siding 3 09-01-2009 07:47 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
