10-11-2010, 01:12 AM
#1
Venting the roof
Background: My house was built in 1937, Block walls, all redwood roof, no tar paper, _ONE_ sofit vent, no other venting.
I've tore down the complete roof and ceiling in the back 1/2 of the house, the only damaged wood was a few ceiling supports (2x4 redwood) near the sofit vent (within 6 feet)
The rest of the redwood was in very good condition.
I added a vent (wirrly bird spinner type) near the front of the house and a whole house fan.
I live in Sacramento, CA and all the south exposure is covered with large trees (most of the house never sees the sun.
Questions:
How much venting do I need?
Is there something that I can/should do to keep out termites (note: there is no wood below the 8' ceiling, except new door side supports that I'll be adding and those will be redwood with steel risers)
10-11-2010, 01:19 AM
#2
Venting the roof
Not sure about your code, but one square foot of venting per 300 sq ft of floor space works here.
A third of the square ft of vent needs to be in the top third of the roof or higher (ridge vent).
Go ahead and apply for a variance, those guys at City Hall can use a good laugh. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
10-12-2010, 12:27 PM
#3
I ask the impossible!
Venting the roof
I'm no expert, but if the house was built in 1937 and has redwood shakes, it's probably loose construction and breathes pretty well on its own.
This sounds to me like it might be a situation that more of the big picture needs to be understood to say what is needed... You say you've torn off interior ceiling, what's the plan? And is there an issue that is causing you to suspect you don't have adequate ventilation?
Consider the house I'm working on now. Originally constructed in 1917 on a pier and beam foundation, then later an addition was added to extend the house 10 feet towards the rear of the lot, then a 10x10 mud room added on a slab. Later still, the house was insulated.
This house held up well in spite of construction methods that aren't found in the joist or rafter span tables used today. The loose construction used 90+ years ago meant it had airflow to remove moisture, and heating was cheap enough that you just made up with it by heating the world along with your house.
Then the insulation took away that free flow of air, trapped moisture and the wood suffered for it because the necessary increases in ventilation didn't happen at the same time.
The point I'm trying to make is that I think it's important to understand the underlying reasons why ventilation requirements are what they are, what kind of construction they're intended to go with, and with that knowledge it becomes possible to analyze whether your situation fits or not.
I found this link that discusses wood roofs, particularly cedar but I'd imagine the principles are similar:
http://www.oldhouseweb.com/how-to-ad...od-roofs.shtml
10-12-2010, 01:18 PM
#4
Venting the roof
Actually the redwood is in the form of boards that cover the roof, then the shingles go on top of that. I have loose fill insulation, but don't know when that was put in.
Just based on what I'm learning so far... my roof was VERY under vented. with the house being about 1100 sq ft, I'd need about 4 sq ft of vents. probably a combo of sofit/ridge.
10-13-2010, 12:06 AM
#5
Moderator
Venting the roof
Here's your CA Code:
Vent each enclosed attic & each enclosed rafter bay ____________________1203.2*
(UBC left issue of enclosed rafter bays up to local BO)
1/8in to 1/4in mesh screen over openings___________________________ 1203.2.1*
(UBC did not allow 1/8in mesh)
Min net opening area 1/150th of vented area OR _______________________ 1203.2
1/300th if 50-80% in upper portion _________________________________ 1203.2X
From: http://docs.google.com/viewer?a=v&q=...h1W5lElSFXE4_w
Gary
Clothes taking longer to dry?
10-13-2010, 01:16 AM
#6
Venting the roof
I'm not sure I understand what that means, code wants me to have a vent on each enclosed rafter bay?
So what is an 'enclosed rafter bay' sounds like everywhere you have an enclosed section of roofing, you need a vent.
I wonder if a ridge vent and 1 sofit vent on each wall would be correct.
10-13-2010, 09:43 AM
#7
Venting the roof
Well, whatever the case, too much is generally better than not enough. Unless it's a hip roof without gables, you can always add exhaust ventilation with gable vents too without disturbing the roof - and powered gable vents may be an option as well. Soffit vents would be good for providing intake, you want intake at the bottom and exhaust at the top, and a balance of having more intake is better than more exhaust. What you don't want is the ventilation trying to pull air from inside the house, this can defeat gas appliance ventilation in the worst case.
10-13-2010, 11:10 PM
#9
Venting the roof
Actually to the best of my knowledge the code is 150 sq ft, but you can go 300 sq ft if you are splitting it equally between intake and exhaust. This 150 BTW is also a requirement of several shingle manufacturers.
If each rafter bay is seperated from the rest, then each rafter bay becomes it's own ventilation zone. You can bore holes at the center of each rafter to create cross venting between rafter bays. Please do not notch rafters as this will weaken them. Then holes must be placed center and no more than 1" diamater preferred. A ridge vent is ideal for this type of design, when a ridge vent is adequate exhaust. Ridge vent doesn't work on every building.
-Grumpy
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
10-14-2010, 12:42 AM
#10
Venting the roof
if your roof is sealed with spray foam though, then no ventilation is needed
10-14-2010, 10:15 AM
#11
Venting the roof
Yes but with some shingles if there is no ventilation, as in the case with spray foam appliled to the bottom of the roof sheathing, your 30 year warranty will be reduced to 15.
-Grumpy
10-14-2010, 12:04 PM
#12
Venting the roof
This is what I heard too, of course each Province/State could have its own rules.
Our house is about 2000 sq. feet, but we just have two whirlybirds. So we should have 6 or 7 vents. It gets incredibly hot in the summer, but we use portable a/c units in our bedroom. I've contacted several roofing companies but nobody seems interested in my "little" project to add vents.
One guy came out to look, but of course he came at the wrong time when nobody was home. He was supposed to quote me on either a ridge vent or more whirlybirds, I haven't heard anything yet. Must be nice to have so much work you can turn people down or ignore them.
10-14-2010, 02:29 PM
#13
Venting the roof
We share the same code. I live in Golden, BC.
Grumpy is absolutely correct. The 150th rule applies unless the ventilation is available both top and bottom.
Each Whirly Bird vent has a stated rating of how many square feet/inches it supplies for the calculation of venting space. See if you can find the make/model and source out that information.
Also, can you see in your attic if the bottom of the rafter bays are blocked off? Some home owners actually stuff insulation in the vents to stop air leaks, which defeats the purpose of the venting space.
I was in Langley/Abbotsford/Mission last weekend. You should have called...
10-14-2010, 10:40 PM
#14
Venting the roof
Canada gets hot ????!!!! I wooda lost money on that...
The insulation that I have doesn't block the ends, in fact it was so compressed it didn't have but about 1" towards the edges. Overall my house has REALLY poor insulation. I'm looking forward to see what a 'real' house feels like this winter.
Two houses down just had a $4,500 roof re-do and he's now got at least two whirlybirds, I have the one I added and I think I'll be getting 2 or 3 more. I got mine because of the whole house fan and nowhere to push the air.
10-14-2010, 11:25 PM
#15
Venting the roof
Right on some more local Bcers  .I live in Chilliwack but do most of my work in Abby,Mission,Langley,etc
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
